Originally posted by Penten50mm Hello there.
I own a 110D, I've been told these cameras are backwards compatible with older lense as long as they are not the screw mount, Is this True? If so, I want to get a 50mm Prime for my body, I know I'd have to deal with the 1.5x crop factor since it'd be a used film SLR lense, I cannot really afford a New AF lense, But getting a MF with the auto-aperture will work for me.
I do alot of portrait photography, What is the best lense for that though? I know the 50mm prime is, but what else? I would like to have something that's zoom, less so then a prime. But a prime is always nice to have.
Thanks!
Unfortunately, used Pentax glass is not as inexpensive as it once was. Lots of demand has inflated the prices. A used A50 f1.4 will cost almost as much as a new FA50 f1.4. None the less an A50 f1.4 or f1.7 is a good place to start for a portrait lens. Depending on you working style, any focal length from 50 to about 100mm or so will make a good portrait FL. M series lenses are a bit more plentiful, and less expensive.
As to a zoom, one of the real bargains is the A35-105 f3.5. This lens is extremely good. It is sharp, contrasty, and good color rendition. Built like a tank also. The down side is it is heavy. You should be able to pick one up for less than $150.00 or so.
