02-26-2011, 01:10 PM   #1
JJD2500's Avatar
Focal length conversion
I have been using a K2000 for about 2 years now.
I have a Pentax 50mm 1:2 (prime) lens from my old 35mm film kit.
I'm a little confused about the conversion ratio when using this lens on the DSLR body. Although is works just fine, I don't feel like I'm getting optimal images from the lens.
When I attach it to the DSLR camera body, I'm asked to input the focal length via the camera dial but I'm not certain what the correct setting is?
Any thoughts, comments, or help would be greatly appreciated.
Thanks,
JD
02-26-2011, 01:13 PM   #2
I have been putting in 50mm
Mand
02-26-2011, 01:27 PM   #3
FL=FL=FL...
It May be the lens. On a dSLR, I've never been particularly impressed with the f2.0 50mm. Maybe that's just me as I'm sure a lot of people use them. Were I you, I'd sell the 2.0 and find a 1.7 to replace it. Infinitely better IMO.
02-26-2011, 01:28 PM - 1 Like   #4
Ash
Community Manager
Ash's Avatar
The exact focal length of the lens (50mm) is what should always be entered, but I would wager there's another reason for the unacceptable results. Would you post some examples of these?
02-26-2011, 01:33 PM - 1 Like   #5
RioRico's Avatar
Oh boy, the crap factor confusion again. Forget you ever heard about 'equivalent' focal lengths and FL conversions. A 50mm lens is a 50mm lens, not matter what it's mounted on. Moving a lens from one camera to another, with a different frame size, does not change the lens. The amount of the image circle that the lens projects changes -- that's the 'crop'. But your camera's SR'bot only wants to know the actual focal length. It doesn't care what the field of view (FOV) is.
Back in the day, I had a 135 half-frame SLR, an Olympus Pen-FT, with frame size about the same as your APS-C dSLR. I got a Spiratone 400mm lens with a T2 adapter, and I thought, OH BOY, IT'S 600MM ON THE OLY! But it wasn't. It was just a 400mm image with the sides cut off. That's all. And that's all that happens when you put any FF or MF or other lens on your dSLR. Part of the image is cropped off.
Have fun!
02-26-2011, 01:39 PM   #6
twilhelm's Avatar
RioRico, you couldn't be more right. (though I think I've seen you write this before)
To the OP, it may be the lens itself. Though I will add that my 50 1.7 and 55 1.8 give me much better pictures than my 50 f2.
But if you think you should be getting better pictures from it, post some. There are many on here with the experience to let you know what is going on!
02-26-2011, 01:44 PM   #7
causey's Avatar
What JeffJS said. Buy a 50mm 1.7, M or A. (The A version might help you with the focus.)
I'm also surprised the 50mm 2 is held in high regard by others.
02-26-2011, 01:50 PM   #8
JJD2500's Avatar
OK, I get the picture. A 50mm lens, is a 50mm lens regardless of the body.
Thanks for the comments.
I'll consider the 1.7, as the 2.0 seems to be standard issue "kit" lens from back in the day.
Special thanks to Ash for giving the strait answer to my question.
I'll post some example shots from this lens tomorrow.
JD
02-26-2011, 03:30 PM   #9
RioRico's Avatar
QuoteOriginally posted by twilhelm Quote
Reiterate? Moi?
Before I were a software engineer, I were a broadcast engineer. Before that, I were a liberal arts major, and I had to write thangs, and stuff like that. I learnt some stuff and thangs. One thang I learnt: REDUNDANCY IS THE SOUL OF COMMUNICATIONS. Repeat forever.
02-26-2011, 05:12 PM   #10
boriscleto's Avatar
Reiterate? Moi?
And I would give you more rep if the forum would let me.
02-27-2011, 07:50 AM   #11
GeneV's Avatar
Have fun!
I think I've agreed with that post before as well.
People really need to dispense with this idea of "equivalence." I learned that long ago when I shot my first medium format.
02-28-2011, 11:44 AM   #12
RioRico's Avatar
QuoteOriginally posted by boriscleto Quote
What?!?!? There's a rep.limit?!?!? This is outrageous! It's a conspiracy! I blame [political-social rant deleted]
QuoteOriginally posted by GeneV Quote
The same subject arises. The same answers apply. Such is life.
And another tale I've told before: Back in the day, when photography was my job, my colleagues and I variously used 135/HF, 135/FF, 645, 6x6, 6x9, 9x12, 4x5 etc -- and we NEVER spoke of crap.factor nor equivalence, because the marketing geeks hadn't invented the terms yet. With each format, one learned what each lens does, that's all. One started with the 'normal' focal length (frame diagonal) and extrapolated from there: 1/3 shorter than normal is wide, 1/3 longer than normal is long, beyond those are very and ultra, etc. Neither rocket science nor marketing need raise their grumly heads. Learn a tool and use it.
03-01-2011, 03:47 PM   #13
Lloydy's Avatar
I have dyscalculia, it's dyslexia with numbers, so I just don't do numbers.
Which might be a bit strange considering I've spent my working life as an engineer and chose photography as one of my hobbies.
To me the numbers don't matter because they make little sense, it's a lens. I know what the lens does, I know which lenses are faster than the others. I have a 'picture' in my head that comes from the numbers that somehow makes sense to me. So the 'crop factor' thing, once I had built my picture of it, became meaningless. Which I guess it actually is ?
Screw the lens on and see what the hell it does!
03-01-2011, 05:30 PM   #14
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by Lloydy Quote
+1
It helps if you learn this, it allows you to pre-visualise a situation and put on the right lens.
body, camera, conversion, dslr, length, lens, photography
focal length pentax k-x Photographic Technique 9 11-22-2010 12:41 PM
focal length landscaped1 Troubleshooting and Beginner Help 48 05-05-2010 03:04 PM
SLR > DSLR focal length conversion? wedge Pentax SLR Lens Discussion 20 07-28-2009 05:05 AM
What is Focal Length Ole Photography Articles 2 05-15-2009 12:20 PM
Focal Length Jimsi777 Pentax SLR Lens Discussion 2 11-09-2007 06:46 PM
All times are GMT -7. The time now is 02:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
