03-01-2011, 09:36 AM   #1
Ricoh Rikenon P 50mm 1.7 on a K100D
Hey there.
There's a Ricoh Rikenon P 50mm f:1.7 prime I'm thinking of picking up on the cheap. I know about the Ricoh pin, having removed it on another lens to avoid problems mounting on my K100D, so that's not a big deal.
What I need to know is, will the "P" on the aperture ring work the same as the "A" on a Pentax PK-A lens? Some say it will, others say it won't.
Cheers,
Bobbo :-)
03-01-2011, 10:47 AM   #2
metalmania's Avatar
I have the same lens on my K100D. The pin does not need to be removed.
"P" is no use. Just use manual mode anyway.
03-01-2011, 12:05 PM   #3
alohadave's Avatar
QuoteOriginally posted by GibbyTheMole Quote
No, it won't. The aperture ring contacts for Ricoh are in a different place on the flange than Pentax, and they likely don't speak the same signals even if they did line up.
03-01-2011, 12:10 PM   #4
Thanks for the info, guys. I'll probably just try to find a Pentax PK-A prime on the cheap.
Bobbo :-)
50mm, camera, dslr, k100d, lens, photography, ricoh, ricoh rikenon, rikenon, rikenon p 50mm
What about this lens: Ricoh AF Rikenon 50mm F2 minahasa Pentax SLR Lens Discussion 10 12-03-2011 03:59 PM
Help with Ricoh Rikenon XR 50mm f/1.7 buckyweet Pentax SLR Lens Discussion 4 07-19-2010 01:20 PM
50mm f1.4 Ricoh Rikenon XR stewh Pentax SLR Lens Discussion 1 06-22-2010 09:30 AM
ricoh rikenon 50mm f1.7 p setting?? dcmsox2004 Pentax SLR Lens Discussion 14 04-07-2009 01:51 AM
All times are GMT -7. The time now is 01:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
