03-03-2011, 01:53 PM   #1
Help! Which Adapter for Vivitar Manual Focus Lens
I have been given an absolutely mint Vivitar 35-105mm f3.2-4 lens, serial number 77200890. On the rear of the lens, it says P/K. It has a great screw-on hood. I can't seem to turn up any information on it, except that it was bought for a Pentax camera years ago. It doesn't seem to want to go on my K-r, and I didn't want to force it. Do I need an adapter? If so, can somebody point me in the right direction? Thanks!
03-03-2011, 02:06 PM   #2
boriscleto's Avatar
Is it possible to post a picture of the mount? The 77 indicates that it was manufactured by Kobori.
03-03-2011, 02:25 PM   #3
boriscleto's Avatar
No need to post a picture.
eBay Guides - kobori vivitar mod to fit digital pentax
The long flange protecting the aperture actuator is preventing it from mounting. It hits the SDM connector. I have a Kobori made 28-200 that was the same way. The black ring with the flange should have 2 tiny screws. Remove the ring, dremel off most of the flange and screw the ring back on.
03-03-2011, 02:53 PM   #4
Thanks so much! I'm retired so have more time than sense, and I'm pretty handy with a Dremel tool from my stint with building miniatures, so I think I can do it. In the meantime, this lens has been sitting a looooong time, and I notice the aperture doesn't close down. Is this something I can fix? Or have fixed? He's a wonderful person, and I really want to use the lens regardless of how impractical it might be to get it fixed.
03-03-2011, 03:07 PM   #5
boriscleto's Avatar
Could be oil on the blades. Could be lack of use. Set it to f/22 and push the aperture lever back and forth. Sometimes that loosens the blades up. If the blades are still sluggish they would have to be cleaned.
03-03-2011, 04:05 PM   #6
Thanks so much. I'll give it a go!
03-04-2011, 07:19 PM   #7
average-guy's Avatar
I "had" the same issue with a Vivitar 80-200 constant F4. The lens was mint and I didn't want to take a dremel to the long "ear" so I removed the flange and put it and the screws in a ziploc bag and I use the lens without the flange installed. I just take extra care when mounting and dismounting as to not bump or damage the aperture arm. Good luck with it.
03-04-2011, 09:03 PM   #8
Take the flange thing off of the lens before you grind it down. Just three little screws.
adapter, camera, dslr, lens, photography, vivitar
What "AUTO" on a manual focus Vivitar lens? emr Pentax SLR Lens Discussion 5 08-06-2010 09:56 AM
adapter for manual focus K mount lens ted neck Pentax SLR Lens Discussion 5 01-27-2010 01:19 PM
For Sale - Sold: Vivitar 100mm f/2.8 Macro 1:1 Manual Focus PKA OR Vivitar Series 1 Macro yyyzzz Sold Items 6 10-22-2009 05:18 AM
For Sale - Sold: Vivitar 100mm f/2.8 Macro 1:1 Manual Focus PKA Same optics as Vivitar Series jjdgti Sold Items 10 10-05-2009 05:19 AM
Vivitar 300mm f5.6 manual focus NaClH2O Pentax SLR Lens Discussion 1 02-09-2007 11:00 PM
All times are GMT -7. The time now is 10:23 AM. | See also: NikonForums.com, part of our network of photo forums!
