03-04-2011, 08:17 PM   #1
Adjustable settings on K-X
I may be displaying my "newbie photographer" ignorance here, but does anyone know if it is possible to manually adjust BOTH the aperture AND shutter settings together on the K-X? I understand how to use and adjust settings in aperture priority mode and shutter priority mode. But, what if you want to adjust both? Is that even possible on any lens that doesn't use only manual aperture?
03-04-2011, 08:21 PM   #2
Yes, you can do it with any lens (literally) - just set the camera to M mode.
03-05-2011, 01:04 AM   #3
axl
Yes, camera needs to by in M mode. You use the dial for adjusting aperture and pressing down Ev button (if I remember correctly) and dial to adjust exposure time...
03-05-2011, 07:57 AM   #4
Marv Toler's Avatar
Your memory is pretty good. I just tried that and it works well, except the button to switch back and forth is labeled "Av".
03-05-2011, 08:30 AM   #5
boriscleto's Avatar
It's even easier if you take the lens out of A mode and use the aperture ring to set the aperture. Of course this isn't an option with FA J or DA lenses.
03-05-2011, 10:46 AM   #6
axl
The problem then is that camera doesn't know the f stop and doesn't meter AFAIK. That means green button metering, counting the clicks to know f stop and of course no f stop in metadata....
03-05-2011, 11:37 AM   #7
boriscleto's Avatar
QuoteOriginally posted by axl Quote
I still consider it easier than trying to keep track of whether I'm changing the aperture or shutter speed. If you don't have 2 e-dials you have to make some compromises.
03-06-2011, 01:09 AM   #8
axl
To each his own
aperture, camera, dslr, k-x, mode, photography, priority, settings, shutter
K200 blurry & not adjustable danielac Pentax DSLR Discussion 3 10-30-2010 05:28 PM
I'm unhappy with K-7 settings. Help me custom the settings like k20. netuser Troubleshooting and Beginner Help 16 09-01-2009 08:39 AM
Super-Tak 200mm/4: too many adjustable rings, who can help? Rense Pentax SLR Lens Discussion 3 07-30-2009 09:54 AM
K10D Custom Settings... Your Settings Gadget_Guy Pentax DSLR Discussion 4 05-25-2008 06:33 AM
All times are GMT -7. The time now is 05:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
