Originally posted by sergysergy should these two do the job to reverse the 50mm 1.7?
just making sure I got the idea right....
Yes, those are exactly the right tools.
Yes, you got the idea exactly right.
Just be aware that you'll be working REAL close.
Will your subjects run off if a lens comes within 50mm / 2in?
Here is a trick: When you get the tubes, set aside the lens-base section, the piece that clicks into your camera mount. Sand- or file-off the black paint on that section, in the area that covers the camera-mount electrical contacts. Now, when you use your macro setup with the tubes, you'll safely short-out those contacts and thus enable Catch-In-Focus (CIF). Do the same with the mount-reversal ring, for when you use it alone and not the tubes. CIF is very useful when shooting handheld macros.
There is a common trick for enabling CIF on K- or M-type lenses, which is to put a bit of metal foil or tape on the lens base, to also safely short-out those contacts. DO NOT DO THIS WITH TUBES NOR REVERSAL RINGS!!! Tape and foil are thick enough that tubes or rings will jam on the mount! Remove paint; don't add foil!
