Originally posted by Tippon If I'm reading this right, could I use my 80-200mm lens and my 35-70mm lens with the right adaptors to get some decent magnification? If so, would it be:
camera body - reverse adaptor ring - big lens - male to male ring - small lens?
Also, could a teleconverter be added to the big lens to give even more magnification, or am I just being daft now?
You *can* use zooms, but you'll likely have lower IQ and smaller apertures than with primes. (Small aperture ==> diffraction softness). Some zooms also have a tendency to creep, so you're never sure of your magnification. Your long primary should be a wide-open prime or you'll likely have vignetting. Your short secondary really needs a manual aperture.
And no, don't put a mount-reversal ring on the primary. A typical stack might be:
camera <-- (mount adapter, if needed) <-- primary <-- M-M ring <-- secondary
For example, my typical ~4x stack is like this:
K20D <-- M42-PK adapter <-- Hanimar 135/3.5 <-- 49-49 ring <-- SuperTak 35/3.5
A faster and slightly shorter stack for 3.75x would be:
K20D <-- M42-PK ring <-- SuperTak 105/2.8 <-- 49-49 ring <-- Vivitar CFWA 28/2
Adding a TC will just reduce aperture and IQ. Unless it's a simple long tube like my Hanimar, the tele already has a TC optical group inside it. IMHO you'll get the best results with the simplest feasible optics.
Originally posted by newarts ...what's the advantage of reverse stacks over extension tubes or bellows?
That is a VERY GOOD QUESTION!! My bible of macro shooting doesn't IIRC mention advantages. (It's 1200 miles away so I can't refer to it this month). I'll guess that the major pro's are:
1) easy to lash together with gaffer's tape,
2) compactness per magnification, and
3) consistency and precision.
With reverse-stacking, and tubes, you can know the exact magnification. That's critical for precise technical work. Put an Industar-50 on 50mm of tubes and you KNOW you're at 1:1. Stack a SuperTak 35 on a SuperTak 105 and you KNOW you're at 3:1. Bellows, and macro-zooming, are just too slippery for such applications. No, my Schneider Betavaron 50-125 enlarger zoom is not a precise instrument, especially on bellows.
The con of reverse-stacking is the close working distance.
Originally posted by yeatzee Well I say M 200mm because i had it at one point and sold it. Its a fairly cheap lens as well, and has 49mm filter threads, and is small/light weight.
Then I guess I should look for one. Zowie, yet another 200...
