03-08-2011, 05:28 PM   #1
Will lenses perform better on K7 than Kx?
I'm wondering whether a current newer model pentax lens (DA) would generally perform better on a K-7 body than a K-x body. Both are fantastic cameras, but i've read where certain problems with a lens, such as back/front focusing, inaccurate focus disappear on newer model/higher performing pentax bodies. Also, would the focus be quicker and have a higher success rate of focus lock-on in the same low lit scenario with a K-7 body as opposed to the K-x? What are some of the main benefits with using a K-7 over the K-x? (other than a metal body, weather sealing, shots per sec., higher ISO and megapixels)
03-08-2011, 05:45 PM   #2
Yes, AF is faster in K7. Also you get the lens focus adjustment with K7 so if you had a lens that needed adjustment it would definitely be better.
03-08-2011, 10:33 PM   #3
selar's Avatar
You can AF correct for one lens on the K-x.
03-08-2011, 11:00 PM   #4
selar's Avatar
Kx has much better sensor compared to K7 according to DxOMark - Sensor rankings
Of all the Pentax dSLRs tested K7 was bottom ranked, while K-x was third best.
03-09-2011, 07:27 AM   #5
Interesting. Do you know why it would autofocus faster? Faster motor? Faster (more powerful) computer?
03-09-2011, 07:30 AM   #6
selar, I would have a bit of a tough time believing that. I've read plenty of times about noise in high ISO pics on the K-7, but is it REALLY worse than the K-x? How could this possibly be?
03-09-2011, 08:12 AM   #7
HEEGZ's Avatar
The only advantage for K-x is the low ISO performance. I felt the K-7 had it beat in every other area and bought it instead. If you plan on taking photos manually, don't overlook the second e-dial on the front of the K-7. It was one of the deciding factors for me.
The only reason I would buy a K-x at this point would be to slap a 40mm limited lens on it and use it as I would a point and shoot for street photography. If you can afford the K-7 though I would be comparing between it and the K-r.
QuoteOriginally posted by outsider Quote
I don't have any problems with the K-7 at 800 ISO. I found that having a faster lens made a big difference in low light. If you are going to need ISO 3200 or higher you might look somewhere else, but the K-7 is an awesome camera and it's ISO performance if over-criticized in my view.
03-09-2011, 08:18 AM   #8
Nah, I don't think so.
In fact, lenses will give better colors on k-x
03-09-2011, 08:27 AM   #9
performance of the same lens will be remain same..
if the same lens mounted on different body, so the output will depend on the body's performance..
03-09-2011, 08:30 AM   #10
Gooshin's Avatar
the K7 uses the same sensor as the K20D (ie, old) , the K-X had a brand new sensor
it is in fact better
03-09-2011, 04:01 PM   #11
selar's Avatar
In fact K-x is rated better than Leica. I am having a hard time believing that as well.
03-09-2011, 04:22 PM - 1 Like   #12
normhead's Avatar
What does everyone have against the K-x?
I'm a bit mystified. I have one and a K20D, and I still use the K20, but only because I'm more familiar with the controls, and I can't get the K-x away fro my wife. There's certainly nothing wrong with the image quality.
03-09-2011, 04:24 PM   #13
selar's Avatar
Anyway to answer the original question will lenses perform better on K7, the DXO mark site compares the same lens on different bodies:
DxOMark - Optical Metric Scores
Why do Pentax lenses score so poorly on DXOmark?
03-09-2011, 06:24 PM   #14
crewl1's Avatar
I have a K-x as well as recently acquired a lightly used K-7.
My experience so far has been that lenses right out of the shipping package are sharp on the K-x, but require a little adjustment on the K-7.
This applies to Pentax as well as third party lenses.
I attribute it to quality control and sample variation.
YMMV
(Personally I wish the K-7 had the K-x's sensor, but I guess that's what a K-5 must be.)
03-09-2011, 09:01 PM   #15
I don't own either model, but I'm guessing that sample variation would be more significant than other factors.
Paul
body, camera, dslr, focus, k-7, k-x, lens, pentax, photography
How's K-7 battery perform for video shooting vizjerei Video and Pentax HDSLRs 4 09-26-2009 06:07 AM
For Sale - Sold: Lenses, lenses, lenses... and a flash! pbo Sold Items 18 05-28-2009 04:35 PM
Making Less Than FF Sensors Perform mithrandir Photographic Technique 0 02-23-2009 05:52 PM
For Sale - Sold: M42 / K / KA / FA Lenses Grab bag of Vintage to Current lenses. 50mm FA f/1.4 MikeDubU Sold Items 10 02-09-2009 12:45 PM
All times are GMT -7. The time now is 11:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
