10-22-2007, 04:35 AM   #1
Time to write to card
Hi all
I'm not sure if this is quite the right place to ask this question, but I sure would like to know the answer!
When one shoots on a slow shutter speed - 30sec, say, or a very long "B" exposure, the camera takes as long to write the image out to the card as it did to take it in the first place - i.e. 30sec for a 30 sec exposure, 200sec (roughly - I've never actually timed it) for a 200sec exposure. Why??? It doesn't seem to make any sense that if you've collected "x" amount of light (albeit very sloooooowly) that you will need longer to "process" it than if you take a 1/4000 exposure which also, presumably, colects "x" amount of light only quickly.
Thanks for your input!
10-22-2007, 04:42 AM   #2
Moderator Emeritus
What is happening is the NR (noise reduction) is writing a 'dark frame' that takes as long as the original image. What the camera is doing is taking that dark frame and comparing it to your picture and mapping out, then removing any hot pixels that showed up in the first exposure. You can turn off the NR in the menu. You don't see this in a faster exposure as the NR doesn't need to map or remove hot pixels then. Some do this process on the computer to speed up the shooting times, I haven't tried that myself and just let the camera do it's thing.
10-22-2007, 04:47 AM   #3
Moderator Emeritus
Here's a couple of threads that discuss this further:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/11546-noise-reduct...rocessing.html
https://www.pentaxforums.com/forums/pentax-dslr-discussion/11489-time-exposur...ite-times.html
10-22-2007, 01:22 PM   #4
Thanks for that! I should have thought to do a search before asking - this forum seems to have the answers to everything!
amount, camera, card, dslr, exposure, light, photography
Using WIFI Card in K20D to See Images on iPod/iPhone in Live View in Real Time ? wll Pentax DSLR Discussion 1 05-16-2009 04:11 PM
K-m Write Speed dave9t5 Pentax DSLR Discussion 13 02-27-2009 10:22 AM
K200D Write Speed Biro Pentax DSLR Discussion 4 01-09-2009 04:47 AM
Let's write a PS handbook... FHPhotographer Digital Processing, Software, and Printing 18 12-11-2008 12:59 PM
Time Exposure - Bulb setting - Read write times Vatis Pentax DSLR Discussion 7 09-05-2007 07:38 AM
All times are GMT -7. The time now is 12:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
