Originally posted by Peter Zack (snip) As for a travel camera, that depends. If you mean going to Europe then maybe, maybe not. The K100D (super) can take AA batteries which could be a life saver. But the charger for the K10D says 240 v 50Hz, so it should be fine anywhere. (snip)
Hey, things not entirely backwards over here in Europe, Peter.
The K10D's battery is fairly common and can often be found in most department stores with a decently stocked camera section, as well as most regular camera stores. However, to avoid any search for a battery (even one this easy to find), I'd always suggest bringing a spare.
The charger for the K10D works fine anywhere in the world with only a proper plug adapter required (not a power converter, just an adapter to fit the plug into the wall outlets used in the visited country). In the USA, plug adapters to fit most wall outlets around the world can be purchased at nearly all Radio Shack stores, as well as Circuit City and similar stores. You can also often find plug adapters at many office supply stores catering to traveling businessmen, such as Office Depot and OfficeMax. Finally, if all else fails, one can easily find the plug adapters at the stores inside any international airport. However, they often tend to cost much more are the airports.
stewart
