03-16-2011, 03:29 PM   #31
I would have to agree since you are using only one body I would go with a good quality zoom lens. Tamron 28-75 f2.8 should give you good range indoors. In addition, I would add a prime lensa maybe a 35 or a fast 50. To help out for those special indoor shots. But 2.8 is plenty fast for most shots. As for zooms past 135mm I would avoid most aren't fast enough for indoors and unless you have no access to getting closer you won't be touching it.
03-16-2011, 08:02 PM   #32
QuoteOriginally posted by justtakingpics Quote
Is the shutter on the k-5 quiet?
With some searching on Google you can find audio samples of sounds so you can compare, but the K-7/K-5 are one of the quieter shutters/mirror actuation sounds around. My K-7 is louder than the new K-5, but that might be because it has many more actuations on it.
So the K-5 is 2+ "levels" quieter than the lesser models. The K10D and *ist DS I had in the past were quite a bit louder than my two current bodies.
Most lesser cameras have a loud crack sound. The K-7/K-5 are more like a deeper "thunk" with the k-5 sounding more like a muffled "thunk."
It's aspects like these that people don't often take into consideration when buying a camera, yet I think it says something about the level of care they put into the engineering. It's part of the reason I dropped the K10D to get a K-5 to go along with my K-7 (I prefer always having two bodies).
The reason I also suggest SDM is because there is a noticeable sound difference between say a DA* 55mm and FA 50mm that uses screw-drive autofocus. Standing by the couple when they are exchanging vows... and hearing a zip-zip-zip of screw-drive autofocus wouldn't be something I would want to have happen.
camera, dslr, lenses, photography
First Wedding Shoot Timtast1c Post Your Photos! 7 07-06-2009 01:52 PM
My first wedding shoot tcdk Post Your Photos! 7 09-08-2008 08:46 AM
wedding shoot vincentgargano Photographic Technique 15 05-06-2008 07:04 AM
A few from my first wedding shoot. NLAlston Post Your Photos! 9 08-14-2007 03:42 PM
First Wedding Shoot qdoan Post Your Photos! 8 08-14-2007 02:15 PM
All times are GMT -7. The time now is 05:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
