Originally posted by switters I recently bought a 540 for my K10D. I noticed yesterday as I was using it that the head tilts and swivels WITHOUT pressing the button. I can't remember for sure, but I seem to recall that when I first got it a week ago I had to press that button before I could move the head. I certainly had to do that with my Canon flashes when I shot Canon.
I have two 540's. They bounce angle can be adjusted on both of them without pressing the button on the side of the hinge area.
That button is identified in the very bad operating manual (page 13) as the "bounce lock release button" Other than that, I can find no references to the button anywhere.
While I was looking just now, however, I did notice that the back of the manual mentions that there is a -10 degrees angle available for the 540's bounce head. And I just discovered something: If you push the flash head forward and down
without pressing in the "bounce lock release button", you can only get it to 0 degrees, i.e., straight forward.
But if you push in the release button, you can push it down another 10 degrees. I guess that is useful for those times when you're close to the subject.
So I'm grateful to you for asking the question. My guess is that the bounce lock release is there to keep you from going down to -10 degrees accidentally, which makes sense. The ability to move the head UP/back without pressing the button also makes sense to me. The increments do click and I've personally never had a problem with either the tilt or swivel feature of this flash.
Will
Addendum with correction: 35mm said "per the manual," so I checked again. Yep, it's there: page 55. I've studied this manual but I've missed that detail about the -10 degree setting in the past. My mistake.
