Originally posted by StigVidar You could also take a photo at 135mm f/5,6 of a curbstone at the other side of a road. It is then easy to see if there is front or back focusing.
Thank you, StigVidar!
I tried your method first, because only minutes after I read about it, my wife took me out for a walk.
I then took pictures of a parking lot covered with small concrete squares, after placing two pencils of different colours at the same distance to focus on. The edges of the concrete squares provided a scale which should be most at focus where the pencils were. As you suggested, I used 135 mm/5.6, and had my camera at various distances from the pencils.
Looking at the pictures at home in my computer, I got a rough indication that my lens/camera combination focuses well.
Pros of this method: very easy and quick to use.
Cons: If you want a more exact measurement, then you should use a more sophisticated method as a complement.
Sten
