03-21-2011, 10:12 AM   #1
Shimming the screen
Hi.
Since installing a split screen in my K100D, I've noticed the focusing's a little off. I ordered a set of shims from Pentax, and I'm going to adjust it myself.
Here's a shot of a focus test chart taken with a Pentax-M 50mm f:1.7:
So, the finished shot is focused about 1/2" in front of where it should be according to the screen. (The point of focus is the center line.)
The question is: Should I try a thinner or thicker shim than the one that's in there now to correct the error?
Thanks,
Bob :-)
03-21-2011, 06:49 PM   #2
Wheatfield's Avatar
I got this from Rachel Katz in regard to my Katz-Eye screen for my K-7, which will also need to be shimmed into position:
The 0.40mm seems to be the default factory size and it is common for a
thinner shim to be required. They are quite inexpensive though, so it would
not be unreasonable to simply order one of each. Thinner shims will move
the indicated point of focus closer to the camera (correction for front
focus) and thicker shims move the indicated point of focus away from the
camera (correction for back focus).
03-22-2011, 04:38 AM   #3
Good to know. Thanks for the info. - Bob :-)
03-22-2011, 03:18 PM   #4
Hypocorism's Avatar
QuoteOriginally posted by GibbyTheMole Quote
Hi.
This might assist in your decision.
Focusing Screen--How to adjust focusing screen--
.R.
camera, dslr, focus, photography, screen, shot
Focusing screen issue. Split-screen out of whack? marcdsgn Troubleshooting and Beginner Help 12 02-24-2011 04:06 PM
For Sale - Sold: Katzeye Optics Split-Screen Focusing Screen for K-7 (CONUS) porterHause Sold Items 2 12-07-2010 05:08 PM
For Sale - Sold: Minolta X-700 Focusing Screen (for you to cut your own split screen) frank Sold Items 3 09-24-2009 10:08 PM
Seeking advice on focusing screen (split screen) for K200D Ari Freund Pentax DSLR Discussion 8 07-31-2009 03:00 AM
Green screen vs White screen backdrop sebberry Pentax Camera and Field Accessories 10 06-14-2009 11:14 PM
All times are GMT -7. The time now is 07:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
