Originally posted by Evolution
Credit to training_editor at dpreview for discovering this, but apparently the K10D firmware update has corrected the lighting-dependent front focus problem. I tested my 50/1.4 again (skeptically) with a number of shots which previously caused front-focus problems. All gone. It focuses perfectly. I'm not sure why Pentax didn't mention this fix in the firmware documentation. Maybe it was unintentional? Maybe it's in my head? I don't really care either way. My 50/1.4 works flawlessly now and I'm thrilled.
I had similar experience, each time Pentax released a new firmware for my *ist D, I hoped that the firmware "secretly" correct something which were very annoying but actually those correction were not officially announced (and of course for Pentax in the past), e.g. the underexposure symptom as well as the yellow light FF problem, etc.
Once or a few times, I found that something seem to be improved and then I post my little inital findings in forums when I just found a little of the few samples which are believed to be correctly made. However, later on, when time goes by, again, I found that actually there *nothing* was changed. The times I saw the "improvement" were just coincidence as the camera was actually behaving quite inconsistently - well, sometimes it could do it close to right but the sucessfull rate is not that high, i.e., most of the other time, it behaved "typically" for typical situations which it didn't work!
My experience is that when we had a great desire to see something happened, sometimes we cannot see thing correctly as our mind has been blockened somehow! :-)
All above are my true experience..
I know that training_editor told that he did repeated comparison and experiment, however, actually, his test samples have not been posted. So, pls be aware that what I experienced in the past may happen again in this case.
Well, I am not saying firmly the possiblity cannot be true, but I think it is very *unlikely* (if Pentax have corrected a problem that they have never been able to re-solved since their first DSLR, why not told this great news in the firmware update annoucement? Do note at least they mention about banding and B mode battery indication, etc.)
