Originally posted by mtansley Not trying to be insulting here since you know how to use the meter (same one that I'm learning to use with my K20d) but is the sekonic accurate or do you have the exposure compensation accidentally set on the meter? Would having or not having a UV or skylight filter on the lens make any difference?
At one point I had three different meters (before I decided on the 358) and checked them all together for amusement (they all reported the same f stop so I assumed each was correct)
Michael
Michael, somehow, or another, I've ended up with two of the L-358 meters. I get the same readings from both.
There's no exposure compensation on the meter, or the K7.
I borrowed a Canon 40D and tamron 17 - 50 lens from the local B&M yesterday to run a comparison. I used the same lens on my K7.
Using the settings indicated by the L-358, The 40D was spot on. the K7 was about a stop and a half underexposed.
i had the exact same situation with my k20D.
So, my conclusion is that there's a problem with the K7.
Well, off to repair again.
