03-22-2011, 03:18 PM   #1
K-7 card slot broken
My memory card slot on my k-7 has always given me grief since I bought it 6 months ago. The last time I removed my card from the camera was no different. When I went to put the card back in, the card would not lock in and read the card. Now I have to put a piece of paper between the card and the door so it will read the card. Any one have any idea why this is happening?
03-22-2011, 03:48 PM   #2
Are you feeling the spring when you push the card in? Or does it just kind of drop in? If you bought the camera New, I would suggest sending it in. If not, and you have the card reading and writing in the camera, I would suggest using the USB cable for transferring rather than removing the card.
03-22-2011, 04:18 PM   #3
I bought the camera new. When I put in the momory card it doesn't feel like the card is locking on place, maybe I bent the lock tab or something. No the spring doen't engage. My camera shop said it would take about a month to send in and get fixed. If thats the case then I'll have to wait until the end of summer just before my warrenty is up. My fix at the moment is upgrading to a 16 or 32 gig card and a small piece of paper between the card and the door, then using my usb cable to transfer data.
03-22-2011, 04:58 PM   #4
wlachan's Avatar
Try another SD card just in case it was the card, if you haven't done so.
03-22-2011, 05:51 PM   #5
card #1 locks in place but doesn't read the card or let me format it. Card #2 doesn't lock in place but with a piece of paper between the door and the card will work fine. The camera store I goto tried 3 or 4 different cards none would lock in place but the camera would read them. I just don't understand..
03-22-2011, 06:24 PM   #6
hcc
hcc's Avatar
Send the camera for repair under warranty. Do it now before an accident happens.:ugh:
03-23-2011, 12:06 AM   #7
QuoteOriginally posted by mduncan253 Quote
Excuse me you buy a new camera and even in the shop it doesn't function properly?
Bring it back, demand a new (not repaired... takes 4 weeks here) since it was allready faulty when they sold it...
camera, card, dslr, k-7, photography, slot
Thought my K7 SD card slot was stuffed - but its not! jeremyhall Pentax DSLR Discussion 4 03-23-2011 03:09 PM
SD card slot on the K5 jpzk Pentax K-5 36 11-24-2010 08:11 PM
Pentax K-7 SD card slot problems ed coleman Pentax DSLR Discussion 7 11-15-2010 11:00 AM
k20d sd card slot problem hitechrr Pentax DSLR Discussion 9 05-02-2010 05:18 PM
Is the SD card slot sealed? (K200D) vk4akp Troubleshooting and Beginner Help 4 05-04-2009 06:22 PM
All times are GMT -7. The time now is 08:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
