03-25-2011, 07:45 PM   #1
Chaos_Realm's Avatar
K-7 Battery Life Issue
Hi guys,
I've had a quick look and couldn't find anything on this issue.
When shooting with my K-7 I will have an issue with it randomly showing "Battery Depleted" and shutting off. I have tested this with 2 OEM Batteries, and it tends to happen when I have done some shooting with Live View. Yes I know that this will deplete battery faster but, the battery indicator will be still showing full battery, and sure enough when i turn it back on it will work perfectly fine! (live View included)
I don't think its a firmware problem but non the less I have to wait to update firmware, as I don't have my cable where I am for the next week or two. (current version is 1.10)
03-25-2011, 08:21 PM   #2
If you're using a grip, check to make sure the full battery is selected. The only other explanation would be that the voltage on your battery was low at the time.
03-25-2011, 08:32 PM   #3
Hi Adam, Thanks for the quick response!
I don't have a battery grip (Yet!).
Would the low voltage be a faulty batteries. I know 2 faulty batteries is unlikely but is still possible.
I know its not cold environment that is causing voltage drop as the temps (although cooler than normal) are not low comparatively.
03-25-2011, 08:32 PM   #4
BigDave's Avatar
I have seen something like this with my K7, and I believe it is when I am using live view and LV is really pulling down the battery. When I switch LV off, the battery level does go back up, but I know I've drained it a fair amount. Early on I got two B/U batteries as I know Murphy's law dictates the battery will die just when that great shot is about to enter........
03-25-2011, 08:43 PM   #5
QuoteOriginally posted by BigDave Quote
I suppose the battery after heavy loading might have a temporary low in Voltage, Its a real pain as I have been using the lv to magnify to 6X-8X to get the focus smack on (with f1.8 on the FA 77 Ltd) I switch of lv and go to shoot or compose and the battery dies! Its a PITA!.
Would having a battery grip help to provide a more constant voltage supply and "fix" this issue?
03-25-2011, 09:50 PM   #6
Live view does suck the power down considerably. The grip can help with that. I don't know exactly what is going on with your particular batteries (age?) however.
03-26-2011, 12:00 AM   #7
QuoteOriginally posted by JeffJS Quote
(age?)
Batteries are effectively still new. Bought one 27th Dec 2010 and the other mid Jan 2011.
I am going to run a firmware update ( I just realised I don't need to have the usb cable to update ) see what that does for it. Not sure if there can be partial errors in firmware V1.10 but I hope that is all it turns out to be!
battery, camera, dslr, firmware, issue, k-7, photography, view
AA battery life jslifoaw Pentax DSLR Discussion 54 06-05-2011 05:26 PM
Battery life for K-x wally1 Troubleshooting and Beginner Help 21 01-25-2011 07:13 AM
K-x Battery Issue gkamieneski Pentax DSLR Discussion 6 12-17-2010 02:51 PM
Battery Life soppy Pentax K-5 14 12-06-2010 02:02 PM
Battery issue with K-x switters Pentax DSLR Discussion 15 02-26-2010 09:06 AM
All times are GMT -7. The time now is 03:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
