03-27-2011, 01:51 PM   #1
Batteries for kx
Доброго дня суток, форумчане Подскажите пожалуйста какие аккумуляторы надо купить, чтобы фотоаппарат Pentax KX начал работать так сказать на полную катушку? Аккумуляторы емкостью в 2100 он даже не воспринимает что делать?! какие купить и какой емкости чтобы наверняка? Заранее спасибо.
03-27-2011, 03:20 PM   #2
twitch's Avatar
Eneloop batteries are what you need to buy
03-27-2011, 03:55 PM   #3
SpecialK's Avatar
And a good peak charger like a La Crosse BC-900.
03-27-2011, 05:41 PM   #4
bdery's Avatar
Eneloops are good, as are the Rayovac hybrids. Both are regular batteries that do not loose their charge when sitting idle.
03-29-2011, 03:46 AM   #5
Reza_RM's Avatar
I am using powerBase 2700 mAh rechargeable batteries came with an LCD rapid charger, They're very good, just make sure your firmware ver is 1.01 or 1.02 and your battery type is selected as Ni-MH in camera when using rechargeable batteries.
03-29-2011, 11:52 AM   #6
Reza RM, подскажите, а как мне определить какой версии у моей камеры прошивка?
03-29-2011, 12:02 PM   #7
K57XR's Avatar
QuoteOriginally posted by Vivjen Quote
Turn the camera on while holding the MENU button down.
03-30-2011, 10:54 AM   #8
QuoteOriginally posted by k57xr Quote
turn the camera on while holding the menu button down.
показал версию 1.0.
03-30-2011, 11:39 AM   #9
K57XR's Avatar
показал версию 1.0.
That is old (original) firmware and has the battery level inaccuracy issue. You need to update it to at least 1.01 or 1.02.
Digital Cameras and Accessories - Official PENTAX Imaging Web Site
Please note: If the upgrade process is disrupted somehow (batteries die) the camera may become unusable. If this happens you will have to send your camera to Pentax and pay for it!
Follow the instructions very carefully! Use new lithium batteries out of the package. Do not use regular Alkaline or even rechargeable NiMH for the upgrade.
Good Luck!
03-30-2011, 10:20 PM   #10
Reza_RM's Avatar
Sry for the late answer!
but thanks to others, they fully answered you.
just for upgrading, format the your memory card, put the bin file in it, press menu button while turning your camera on ! and everything will be completed in less than 3 mins.
just as others said make sure you use a set of full charged batteries.
after completing the installation turn off your cam, delete the bin file and enjoy your cam
good luck
03-30-2011, 10:22 PM   #11
FYI this isn't a troubleshooting question. Moving this to the DSLR section.
04-01-2011, 01:55 PM   #12
+1 Eneloops
04-01-2011, 05:26 PM   #13
dmfw's Avatar
I have Eneloop also. My only issue, after one year the batt. life is about 60%. However, they are the best I have used.
04-01-2011, 05:34 PM   #14
QuoteOriginally posted by dmfw Quote
dmfw,
I used to have the same problem. I solved it by using the rejuvenation feature of my charger...I don't know if they are "like new" but for sure they are much better than without the rejuvenation
04-02-2011, 07:46 PM   #15
Wow, Eneloop, eh? Yall have given me something to google. I have just been using lithiums - get thousands of shots from a set and have managed to snag them on sale with coupons. The rechargeables just don't seem to last long enough to mess around with charging all the time. I'm going to look into Eneloop. They a rechargeable? Thanks!
camera, dslr, kx, photography
AA Batteries for the K-X dmfw Pentax Camera and Field Accessories 12 01-22-2010 10:03 PM
I'll try these batteries in my K-x wll Pentax DSLR Discussion 22 11-10-2009 12:07 AM
K-x and CR-V3 batteries? retroflex Pentax DSLR Discussion 6 10-27-2009 12:49 AM
best batteries?? strictlypentax Pentax Camera and Field Accessories 13 06-17-2009 07:21 AM
Batteries for K-m?? Mystic Pentax DSLR Discussion 10 06-17-2009 12:03 AM
All times are GMT -7. The time now is 02:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
