Originally posted by cbaytan Real creepy question is when I see K200 RAW files are about 16MB when K-7's are about 14MB, I guess that shows K-7 compresses RAW files, I hope it is using a not a lossy compression method like Nikon does. Anyone knows?
PEF compression is lossless. No information lost, just stored in a more compact form. Also note the higher file sizes don't necessarily indicate more detail. They might as well just indicate more noise. The more a signal resembles noise, the less compressible it becomes.
BTW, your comparison images differ in so many ways that you can not honestly believe you are seeing a difference between CCD vs CMOS. You'd need a much more controlled experiment to even begin to touch up the differences.
Originally posted by JohnBee TBH, I don't think any of the images posted expose the differences(if at all possible) given that were talking minute dynamic range difference, and so I'm guessing your images are showing the in-camera settings/processing between both units rather than that of substantial image attributes.
+1
Originally posted by TOUGEFC I dowloaded the raw of the "peppers" And opened them both in lightroom and applied the exact same WB to each and did a resize for upload and nothing more, here are the results-
Your nice comparison shows that the backgrounds are very different in the two images. One cannot even begin to start discussing sensor differences when the comparison images differ that much.
