04-03-2011, 06:52 PM   #1
fewayne's Avatar
Wacky color balance in sequence shooting
When I run my K-7 in high-speed burst mode in RAW, I sometimes get different color balance out of the images. I am baffled as to why. It's not a killer, since I've got plenty of latitude for correction in RAW, but why on earth does it happen?
These were shot in M mode with an old Vivitar Series 1 70-210 @210mm, probably wide open at f/2.5. I pulled them into iPhoto and AFAIK haven't touched either, other than to export them as JPEG.
(Please ignore the egregious exposure & focusing errors in these frames of a barred owl, and concentrate on the color balance.)
What gives?
TIA,
rw
PENTAX K-7  Photo
PENTAX K-7  Photo
04-03-2011, 08:06 PM   #2
hcc
hcc's Avatar
Do you have any form of in-camera PP set? I understand that you shoot RAW but these might still be relevant.
I do a lot of Hi continuous shooting and I had a few shots like yours. But very rare... more like 5 in 1,000 shots. (For example, I did 400 shots last Friday without a glitch.)
When I started to shoot burst, right at the beginning with my K-7, I had some trouble with in-camera PP. Now I switch off ALL in-camera PP (*) and i have not more problem, but an occasional shot like yours, but very rare.
NB: (*) I do keep the copyright info as it takes no CPU. I tried with and without copyright infos and it makes no (zero) difference.
Hope that the info will help.
04-05-2011, 12:40 AM   #3
typical pentax exposure problem
Hi, I've had similar issues on my GX10 (K10 clone) but not my K-X.
I think this is a Pentax white balancing problem. The camera samples small areas across the image and aims to set a balance. Minor shifts in image brightness and hue from shot to shot, (could be caused by cloud cover or slight shifts of the camera) seem to be at play here.
No one was able to explain why I got different colour balanced images in two consecutive shots - I've put it down to a poor quality colour sampling/balancing system in some Pentax cameras. Never heard of this happening with Nikon cameras though.
Now seems to be fixed at least in the K-X as it has never happened with this camera.
04-05-2011, 03:59 AM   #4
The only comment I can add is that my experience with two K5s is that the K5 white balance is much more aggressive than it was with a K7. I always shoot in RAW. I have noticed that the slightest change in the subject can produce a change in white balance. I am assuming you had it set to Auto white balance, as that is the only time I have experienced the problem. Setting it to "Daylight" or any other fixed setting eliminated the problem for me.
04-05-2011, 03:19 PM   #5
fewayne's Avatar
QuoteOriginally posted by jlaubza Quote
It would have to have been a pretty fast shift, or a supersonic cloud, because I shot these in hi-speed burst mode (i.e., they were a fraction of a second apart). And if you examine the two images you can see that they're pretty much identically framed. Maybe something later in the toolchain is at fault, but IIRC these looked this way on the camera screen too.
04-09-2011, 04:33 AM   #6
I think Delgado raises a possible cause - auto WB - that is what i was using when I got my colour shifts. What were you using for your shots?
Anyway, persevere with your question, I'd really like to know why this happens.
04-09-2011, 08:48 PM   #7
fewayne's Avatar
Was definitely auto WB. Maybe I'll get out and shoot a bunch in auto and manual and see what happens. Thanks for the ideas!
04-09-2011, 11:24 PM   #8
this is normal for the K-5 in my experience... my K-x had better AWB.
balance, camera, color, color balance, dslr, mode, photography
Inconsistent color balance in K7 Jaboney Troubleshooting and Beginner Help 21 04-06-2010 12:13 PM
K-x: Best Body Color for Street Shooting Dubesor Pentax DSLR Discussion 23 01-22-2010 08:33 AM
Need photoshop color balance help spystyle Troubleshooting and Beginner Help 8 11-30-2009 07:17 AM
RAW vs Manual White Balance for Color Cast Correction JCharles Pentax DSLR Discussion 18 11-09-2008 07:35 AM
Do oversaturation and warmer color balance sound like sickness? Adnan EROL Photo Critique 7 11-12-2007 06:19 PM
All times are GMT -7. The time now is 10:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
