04-04-2011, 01:58 AM   #1
Dark Pictures
I have an *ist Ds and yesterday whilst I was taking pictures both indoors with the flash and outdoors on a bright sunny day, the pictures appeared darker than normal (on the playback). When I put them on the PC they are as dark as the view on the camera..
Any solutions would be great as I need the camera to work for a day out on Wednesday
Thanks in advance
Stibbok
PS only my second post so please be gentle
04-04-2011, 03:07 AM   #2
Moderator Emeritus
We'd need a lot more info and maybe a sample shot to view with EXIF attached. For example what shooting mode? What metering method? EV setting? ISO, Shutter and aperture settings?
04-04-2011, 03:33 AM   #3
Hope I got this right..... and the EXIF info is shown
04-04-2011, 03:49 AM   #4
I cannot see the EXIF info so I got the info off the card
Auto Pict
AF.s
1/3000
F6.3
-2.oEV
ISO 200
300mm
07:51am
facing south
Is there anything else I need to add as I am new to this side of photography I have always pointed and shoot on Auto picture.
04-04-2011, 04:58 AM   #5
Your EXIF info of interest is "-2.oEV".
"EV" stands for exposure value and you can set it on your camera to underexpose (below zero) or overexpose (above zero) your images on purpose.
This means you underexposed the image shown by 2 full f-stops!
In other words you underexpose your images by a four times too fast exposure time.
Solution: simply push the exposure correction button (the "+/-" button on the top right) and regulate the value to "0.0").
Hope this works...
04-04-2011, 08:29 AM   #6
What kind of a flash are you using that will sync to 1/3000 (or 1/300 for that matter)? I know many will but the built in, for instance, will not. With EV -2, at 1/3000, unless you are shooting straight into the sun, it's going to be dark. Even then, you'll see a bright spot for the sun and the rest will be nearly black.
camera, day, dslr, photography, pictures
Dark purple pictures from K-X luma Pentax DSLR Discussion 7 09-20-2010 03:07 PM
Dark pictures sometimes on K20D. jbrowning Pentax DSLR Discussion 18 08-04-2010 08:09 AM
K7 wont take pictures in dark?? XeroX Pentax DSLR Discussion 14 08-03-2010 04:41 PM
Pictures too dark Sargmaster Pentax Camera and Field Accessories 9 12-15-2009 03:53 AM
K10D Lens Help / Dark pictures Amydaveg Pentax DSLR Discussion 2 04-05-2009 08:04 PM
All times are GMT -7. The time now is 05:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
