10-27-2007, 03:50 PM   #1
atnbirdie's Avatar
K100D Custom White Balance Memory?
It appears to me that once I set a custom white balance, even if I turn off the camera, the CWB settings remain unchanged. Can anyone else confirm this? I can't find any mention of how volatile the CWB settings are in the manual.
10-27-2007, 05:03 PM   #2
SpecialK's Avatar
Sounds logical to keep the setting until it is changed. The manual, page 119 "Adjusting the White Balance Manually", says you can "store delicate shades...".
10-27-2007, 05:03 PM   #3
Nick1946's Avatar
Re:custom white balance
It will remain unchanged until you use the "Fn" button and then go in and select something else for the white balance.
10-28-2007, 07:05 AM   #4
atnbirdie's Avatar
K100D Custom White Balance Memory- Answer
I' got some time to do some experimenting and the Custom White Balance (CWB) settings definitely remain in memory until you specifically change them. You can change the WB setting to any other setting (AWB, Daylight, etc.), take pictures, and when you come back to the CWB option, the settings are unchanged from the last time you set them.
The CWB settings remain if you turn off the camera. I even removed the batteries for 7minutes and the CWB were the same when I turned it on again and took a picture using them.
10-28-2007, 02:29 PM   #5
Does this mean that if I set custom white bal. and leave it that every time it is used the custom white will be effective? If this is true, why would you ever change it? Sounds too good to be true.
10-28-2007, 03:01 PM   #6
axl
QuoteOriginally posted by dwssas Quote
You would need to change it for different kind of light, if you take CWB in room A with so much of daylight, and so much of inadescent light plus some cndles, it will be effective. But as soon as you use that setting in different lightning conditions it will be rendered ineffective...
10-29-2007, 05:18 AM   #7
AXL---thank you. That makes sense.
balance, camera, custom, custom white balance, dslr, photography, settings
setting custom white balance grinchicago Troubleshooting and Beginner Help 4 05-09-2010 09:06 AM
replicating custom white balance in kelvin + offsets? mattdm Pentax DSLR Discussion 8 07-03-2009 08:32 PM
Coffee Filter For Custom White Balance Settings? stewart_photo Photographic Technique 13 01-01-2009 07:52 AM
Infrared - Custom White Balance Makes A Difference in RAW carpents Photographic Technique 16 10-30-2007 11:04 AM
Setting custom white balance. Deni Pentax DSLR Discussion 8 07-15-2007 04:05 AM
All times are GMT -7. The time now is 06:46 AM. | See also: NikonForums.com, part of our network of photo forums!
