04-06-2011, 12:36 PM   #1
K100D - something's out of alignment here
Sometime in the last month or so, my K100D has lost its sense of "verticality" - every time I try and line up a strong vertical or horizontal element with the frames in the focusing screen, I get a picture that is a little bit skewed to the right.
I would guess this means either the focusing screen or the sensor has been bumped out of alignment. Can anyone give me some tips on how to figure out the real problem, and a rough idea as to how much it would cost to have fixed?
I may be upgrading to a K-r sooner than I thought.....
04-06-2011, 01:09 PM   #2
Have you done some controlled tests to verify this? The K100 doesn't have a built-in level, after all!
04-06-2011, 01:33 PM   #3
I'm headed in the direction of controlled tests, as soon as I can find the time, and my smaller spirit level. My 3-foot framing level isn't quite the right tool for this job.
What I have now are shots lined up via the framing marks in the viewfinder, of things I believe to be reasonably close to horizontal (window frames, the shoreline of the World Showcase Lagoon at Epcot), and they definitely aren't horizontal in the pictures.
04-07-2011, 12:06 PM   #4
Andi Lo's Avatar
This have been my experience with my K10D as well. It always tilt slightly to the right, so I just manually compensate for it. After a while you get the hang on how much to tilt it. Seems to be pretty common with K10D, although this is the first time I've heard it happen to k100D
My K-x doesn't suffer from this problem to the same degree. I've never done controlled tests on it though. Live view is much superior when I want things perfectly lined up anyway (and is always accurate)
04-07-2011, 12:12 PM   #5
SpecialK's Avatar
Both my bodies do the same thing. The leveling tool in Elements is probably the most used :-(
alignment, camera, dslr, k100d, photography, screen
B+W Slim CPL + DA Limiteds (15 & 35) - Something's wrong gfonso Pentax SLR Lens Discussion 11 04-16-2012 05:39 PM
Metz AF illuminator alignment? Ratmagiclady Flashes, Lighting, and Studio 2 12-26-2010 12:29 PM
Manual alignment HDR software? timstone Digital Processing, Software, and Printing 6 04-08-2010 01:11 PM
Pentax Alignment/QC schmik Pentax DSLR Discussion 14 08-14-2009 05:04 PM
K10D mirror alignment problem? J2R Pentax DSLR Discussion 4 07-14-2009 09:42 PM
All times are GMT -7. The time now is 12:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
