04-13-2011, 02:51 PM   #16
kh1234567890's Avatar
QuoteOriginally posted by outsider Quote
Good points. I like the idea of different converters giving different renditions, will give me a reason to try several programs, however, the converter that comes with pentax is just a simple, watered down program with little features. It does make a nice browser if you're looking to browse very quickly through hundreds/thousands of images and quickly convert/edit them
You should try Silkypix 4, which is really the full version of the Pentax DCU. Once you get used to the interface it is very capable and fast. Betas of Silkypix 5 also look very promising.
04-13-2011, 03:07 PM   #17
Ash
Ash's Avatar
OP, you need to understand the utility of RAW and how as a 'digital negative' RAW "images" should never be thought of as a finished product as you synonymously expect it to be with JPEGs. RAW images are always considered 'processed' once converted to JPEG even if by default settings by definition, which rarely produce images showing the full capability of the RAW format.
04-13-2011, 03:13 PM   #18
OK....
Here's your challenge if you wish to accept it
This is a paired RAW+JPG from my K-x
that suffers from a pretty strong/diastrous magenta light problem
(red and blue LEDs only)
IMGP4490.DNG
and
This ought to show convincingly that RAW is superior -
see if you can recover it to some semblance of normal -
and please explain why a RAW conversion (any processor you care to use) is superior to the JPG?
Well.......I may just have to take you up on this ;0)
04-13-2011, 03:15 PM   #19
Thanks......
04-13-2011, 03:16 PM   #20
QuoteOriginally posted by kh1234567890 Quote
Will do. I wonder if full version of silkypix comes with the k-5?
04-13-2011, 03:21 PM   #21
OK....
that suffers from a pretty strong/disastrous magenta light problem
IMGP4490.DNG
and
Cool! thanks -
looking forward to your results
and explanation why RAW conversion is better -
Suggestion, if I may, please post your results at 800pixel max width so that we can all see them without sideways scrolling?
Thanks,
04-13-2011, 04:15 PM   #22
Ash
Ash's Avatar
The full version of SilkyPix software does come with each Pentax dSLR kit, and it's version 4 that comes with the K-5.
04-13-2011, 05:39 PM   #23
That's news to me, when did Pentax start doing that?
04-13-2011, 06:25 PM   #24
samples...
Here are a few samples from a slightly different perspective...
Here is the straight jpg version of a shot, with in-camera settings...
K-5, ISO 80, 1/100sec, F5.6, Sigma 10-20mm @ 20mm.
This same jpg was opened from Adobe Bridge into PS and "Saved As".
This DNG file (raw) was opened in FastStone Image Viewer and saved as a jpg.
You can see that it more or less used the embedded settings from the jpg preview.
This is the DNG file opened in Adobe Camera Raw and saved as a jpg with no manipulation from me, i.e., just the defaults from ACR.
One of the final renderings after working on it in ACR and FastStone. One of the issues I had with this image, was the way I wanted to render the top left and right corners of the sky.
Working on the jpg at that level of saturation, caused a lot of separation of the blues into distinct bands, but I was able to somewhat control it within the raw file.
I still had to chop off a bit at the top, but I more or less got what I wanted.
04-13-2011, 06:27 PM   #25
OK....
IMGP4490.DNG
and
Thought I'd give it a shot. You like this? Try it with the jpeg.
PENTAX K-x  Photo
04-13-2011, 06:47 PM   #26
Ash
Ash's Avatar
QuoteOriginally posted by MPrince Quote
Every camera I've bought from the K100D onwards had the CD-ROM for the SilkyPix software, both for RAW conversion and JPEG editing. Certainly nowhere near as refined as ACR and Photoshop (which is what I've always used) but at least Pentax gives you that option.
04-13-2011, 07:54 PM   #27
JohnBee's Avatar
OK....
Quick and dirty RPP job:
dbl checked the curtains and spot areas, apparently they are green(shrugs).
04-13-2011, 11:20 PM   #28
QuoteOriginally posted by dvest Quote
That is very impressive - be grateful if you can please tell us how your result was achieved, please?
OK here's the JPG original -
just resized to show the pretty horrendous magenta problem:
Now the Post Processed JPG -
you have to take my word for it that it was the JPG I processed -
Both shots should have the EXIF still attached
(caveat: PhotoBucket can drop metadata)
Once others have detailed what was done to achieve their results from the DNG/RAW file
I'll describe what it took to get my result from the JPG.
04-14-2011, 01:39 AM   #29
The first image is a screen shot of all that was done in Adobe Camera Raw. The second was after opening it in Photoshop and just making some color balance and Hue and saturation adjustments. I had to do it again to get the screen shot. The first time I was in a hurry and didn't notice the color of the curtains so I made them green this time.
I'm also impressed with what you did from the jpeg.
PENTAX K-x  Photo
04-14-2011, 01:57 AM   #30
But that's just a watered down version for Pentax, not the real full SilkyPix software.
camera, cameras, contrast, dslr, files, pentax, photography
Post your "Park Bench" "or "Picnic Table" images tessfully Mini-Challenges, Games, and Photo Stories 2201 3 Days Ago 03:25 PM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
"Raw to Jpeg" color different in Camera output and Pentax software output provia Digital Processing, Software, and Printing 6 07-11-2010 01:18 AM
"Portrait" vs "Landscape" files sizes utopiaimagesonline Digital Processing, Software, and Printing 7 12-22-2009 11:17 AM
Pentax "A" lens and "F" 1.7X converter on K10d yyyzzz Pentax SLR Lens Discussion 4 07-09-2009 05:04 AM
All times are GMT -7. The time now is 06:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
