Originally posted by MikeMike596 I'm Trying to Self Portrait Myself using a Timed Shot (12 Seconds Setting). But it seems to not focus on me at all.
its either All blurry or its Focusing on the Wall in the Background & not me.
I believe on a self-timer shot when you press the shutter button the camera locks focus on whatever the lens sees -
Since you are not in the picture (yet) the lens will focus on the wall that it is pointing at - hence the focus on the wall and not you even when you eventually get into the frame -
as for the all blurry since the wall is plain, the camera may not have anything to focus on... hence all blurry.
So to get yourself in focus on a self portrait - probably it's better to use a remote to trip the camera - so that the camera actually can focus on you. Pick a single focusing point (page 117 in your K-x manual) that you know will fall on you - probably the center focus point? Or the default 5-point AF probably would do as that is somewhat center weighted.
A remote for the K-x can be found for only a few dollars mail-order from China/Hong Kong - I'm sure many here can give you a link.
Or obviously you can put a "dummy" - something for the K-x to focus on in the same position as your face - then after pressing the shutter button - replace that with yourself.
