04-18-2011, 09:11 AM   #1
hahifuheho's Avatar
K200D and Expand Dynamic Range
Hi!
I have a question, does any one know if setting Expand Dynamic Range "ON" on a K200D (or any other camera) would make any difference if shooting in RAW? If not, can this feature be "turned on" while extracting the JPEG in Pentax's Digital Camera Utility?
Thank you.
04-18-2011, 09:52 AM   #2
QuoteOriginally posted by hahifuheho Quote
Hi!
Thank you.
Well, on the K5 at least, Expanded Dynamic Range widens the available ISO range from what is "normally" available. It has to be turned on before taking the shot, though, it's not something you can decide you need when downloading. I wasn't even aware that the K200 had this option.
04-18-2011, 10:08 AM   #3
Fries's Avatar
I never found it helpful. Anyway here is another thread on this subject:https://www.pentaxforums.com/forums/pentax-dslr-discussion/119522-k200d-d-range-feature.html. But there have been more people discussing this topic on this forum. I humbly suggest you use the search function like I just did! (Hint, use 'show Posts'.)
04-18-2011, 10:22 AM   #4
hahifuheho's Avatar
Ah, yes, they had it there, thank you!
"First answer is simple... no effect on a RAW file at all. Think of it an adjustment to response curve used to develop that raw file into a jpeg in the camera itself."
As someone there said "I'll be avoiding the D-range from now on." and will happily shoot ISO 100 again.
Again, thank you.
04-18-2011, 02:16 PM   #5
Jonathan Mac's Avatar
It does have an effect on RAW - it will be one stop underexposed. This is how it works & youŽll have to bear it in mind if youŽre going to develop the RAW file on your computer.
I initially assumed photos would be better with this enabled, but youŽll get far more dynamic range developing the RAW with virtually any computer software than you would switching on the DR function & using in-camera jpegs. I no longer bother with it.
04-19-2011, 10:13 AM   #6
QuoteOriginally posted by Jonathan Mac Quote
This seems about right for my K-x using the equivalent Highlight Correction On
The RAW is underexposed and if the RAW processor does not "understand" this feature the conversion can come out underexposed - sometimes with quite detrimental effects like color balance - which can be very difficult to correct -
Seems contradictory for RAW - but that is what I found in the early days of the K-x when some of the processors had not yet fully supported the K-x - even DNG - so it appears that Dynamic Range expansion and/or Highlight Correction is a specific feature that is not in the standard JPG features, so needs specific support by the processor - fortunately it has been around Pentax dSLRs long enough that it is mostly supported even early on for new models - but it is not a guarantee.....
Long story short - it is probably much better to avoid it if shooting RAW - unless you have tried your processor and have confirmed that it can convert at its default/camera settings correctly - ie: look similar to the (embedded) JPG.
However Dynamic Range expansion, or in my case Highlight Correction, is not totally useless - as it does seem to protect the highlights.
Grossly overexpose any shot and even RAW cannot recover it -
so shooting RAW is not a panacea to sloppy exposure/shooting.
(although I have been told it is a solution to world peace....)
04-20-2011, 07:55 PM   #7
Interesting; I have not experienced underexposure when trying the DR + RAW on the k200, but I can't say there are benefits either.
Paul
04-20-2011, 08:00 PM   #8
QuoteOriginally posted by tibbitts Quote
Most likely is because the RAW processor/converter actually understands/supports that feature in your dSLR -
it is only in some cases where the processor/converter does not understand/support the feature
(since it is not a standard JPG feature) - that the result can look underexposed.
camera, dslr, k200d, photography, range
Dynamic Range on the K-x Shahmatt Pentax DSLR Discussion 33 04-22-2010 03:51 PM
High Dynamic Range ve2vfd General Talk 2 09-17-2009 04:03 PM
K200d - Expanding dynamic range Tedi Troubleshooting and Beginner Help 2 05-25-2009 07:08 AM
Dynamic Range of K20D and K200D cbaytan Pentax DSLR Discussion 8 05-22-2009 08:04 AM
Dynamic range of k200d sinus007 Pentax DSLR Discussion 11 07-26-2008 02:23 AM
All times are GMT -7. The time now is 09:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
