04-24-2011, 09:27 PM   #16
if you see it in the viewfinder, it's not on the sensor. if you see it in your pictures, it is.
04-24-2011, 10:05 PM   #17
Laurentiu Cristofor's Avatar
QuoteOriginally posted by freddykrueger Quote
QuoteOriginally posted by sterretje Quote
As far as know, none of the Pentax dSLRs has that functionality.
645D can do that. It has even a dial especially for it.
K-7 can do that too. Without the direct control though. It's in the timer menu - the M.UP setting. I expect the K-5 can do it as well.
See what you miss for not reading the manual!
04-25-2011, 12:21 AM - 1 Like   #18
cbaytan's Avatar
QuoteOriginally posted by vegabraveian Quote
Oh.. I see..so Pentax Kx doesn't have mirror lock up.....maybe i have to use slow speed to clean inner sensor from dust yah..(
I guess I couldn't make myself clear, functionally it does have a MLU, 2 sec delay will do in most cases. You'll understand better when you check this graph.
Nikon D200 mirror slap vibrations
Here is the full link
http://aaronlinsdau.com/gear/articles/d200_vibration.html
04-25-2011, 03:22 AM   #19
freddykrueger's Avatar
Oh.. I see..so Pentax Kx doesn't have mirror lock up.....maybe i have to use slow speed to clean inner sensor from dust yah...I Think my K-x shown few dust because I often change my lens and maybe my sensor exposed by few dust...
It's not affect but I feel not comfort when I look at the viewfinder and there is (look like) black point inside...I'm sure there is from my camera because i tried few lens and having the same dust position....
Sometimes I think it from the viewfinder but it's not proven before I clean my sensor....I hope it's fine...
If you can see it in the viewfinder, it isn't on the sensor. But if you want to clean the sensor, you can activate cleaning in menu, it will lock up the mirror and you can clean the sensor with a rocket blower.
04-25-2011, 08:32 PM   #20
If you can see it in the viewfinder, it isn't on the sensor. But if you want to clean the sensor, you can active cleaning in menu, it will lock up the mirror and you can clean the sensor with a rocket blower.
Oke...get it..that's what i want to do...
I should read the manual book but unlucky me...It's on Japan language and there is no English at all..I'm blind with this camera...if there someone have the PDF K-x I will be happy....
04-25-2011, 08:35 PM   #21
QuoteOriginally posted by cbaytan Quote
A and N Photography: D200 vibration on a tripod?
You're clear, I just don't understand with menu tools on K-x honeslty...I'm just afraid to try that might be having bad effect to my camera....
04-26-2011, 12:36 AM   #22
You can find it @ pentaximaging.com under the support -> downloads and literature section.
05-05-2011, 10:18 PM   #23
Live View Mirror Move Up
Is there any value in using live view for reducing potential camera vibration due to mirror movement during the use of autobracketing. In a K-X you can't use 2 sec timer (mirror move up) and autobracketing together. I don't fully understand this up and down movement of the mirror that is mentioned here in live view.
Thanks,
Mike
01-11-2012, 09:27 AM   #24
OrangeKx's Avatar
I was playing around with this today. The mirror lock-up works using the Self-Timer and the IR remote. Set the self-timer with the 2 sec. option or if using the remote use the 3 sec. option (I have the remote and it works great). See pages 131-135 of the K-x Operating Manual. My also want to also set "AF with Remote Control" to ON so the camera will auto focus when the IR remote is used. Do this in Custom 2 - #11 - default is 1 (off) (see page 135 of manual).
camera, dslr, mirror, photography
Question RE: Mirror Lockup on Asahi K2 geekette Pentax Film SLR Discussion 10 04-16-2011 10:36 PM
K-7 Mirror lockup and timelapses jaitas Pentax DSLR Discussion 2 05-18-2010 08:32 AM
ZX-30 mirror lockup blackbirdoor Pentax Film SLR Discussion 15 05-20-2009 02:51 PM
Pentax K10D Mirror Lockup MLU vanchaz2002 Pentax DSLR Discussion 12 12-12-2008 07:32 PM
Mirror-Lockup no more than 2sec ? mer Pentax DSLR Discussion 18 01-10-2008 01:03 PM
All times are GMT -7. The time now is 11:50 PM. | See also: NikonForums.com, part of our network of photo forums!
