Originally posted by jmdeegan But some have mentioned the 100d is better in low-light scenarios. How much better? For example, last night I was taking pictures in my living room, just messing around with the wife's canon S2 on continuous mode, and after the first shot, there was no flash. so the rest of the pictures are pretty much useless, even though the room itself was decently lit.
Just trying to understand this comment which was made earlier in the thread-is it a substantial difference, or one where I just need to adjust a little differently with one camera versus the other?
Either the K100D or the K10D is going to be significantly better in low-light than the Canon PowerShot S2 (or S3, or S5). So forget about that.
Now, is the K10D significantly worse than the K100D? Depends on who you ask. Ask a K100D owner, and the answer may be yes. Ask a K10D owner and the answer is either no (that's my answer) or not significant enough to offset the other advantages of the K10D (my other answer).
I just shot two photos here in my living room. Both were taken at ISO 1600, f/4 @ 1/50th sec. One was shot with the K10D, the other was taken with the Pentax *ist DS.
Click here to see the two shots. I uploaded them to a Picasa Web Albums gallery so I could leave 'em large for comparison. Marked 'em A and B. I think the 6 MP *ist DS's noise should be pretty similar to what you'd see with a K100D.
You tell me, which is better or worse? Which was taken with which camera?
NOTE that I didn't use the same lens on both cameras. One camera had the Pentax 16-45 f/4, the other hand the Sigma 18-50 f/2.8 macro. The photos were given NO post-processing at all. I opened them in Picasa, which can read PEF files but not interpret the EXIF data in them. Because both were shot raw, but both are now the same size, one of the files has been sized down more than the other. But otherwise these are pretty much straight from the cameras.
It's not a fair test for many reasons. Perhaps I should have used the same lens on both cameras. But the main reason is it's not fair, is that it's not fair to EITHER of the cameras. It shows both cameras working in bad light -- which cameras don't like. Both cameras can do a LOT better. But if the light's right, the K10D can, um, do more better. ;-)
Quote: Other than that, I am getting to the point where it's like analysis paralysis. I think either one will be nice to have, I just want to decide and start learning....
I can so relate. Analysis Paralysis is my middle name. William Analysis Paralysis Porter.
Will
