04-24-2011, 09:42 AM   #1
K200D Focus Sticking
Anyone experienced the K200D focus "Sticking"
Problem:
Manually focus to mimimal focus distance... press shutter half way to AF... camera briefly locks focus... when shutter is fully depressed the camera winds the focus all the way to infinity and takes a blurry picture. After that the lens is "stuck" at infinity.
Trouble shooting:
- This happens with ALL lens types... DA*, FA*, DA, Ltd etc
- After the lens gets "stuck" at infinity you need to manually try to force it past infinity and then bring it back to shorter focal distances.
- with screw drive lenses there is forceable resistance when trying to unstick the focus ring. Once is has broken free it spins freely. With SDM lenses since there is a clutch the focus simply does not turn until you wind it further to infinity and then bring it back
Any help is appreciated...
Chris
04-24-2011, 12:31 PM   #2
Jonathan Mac's Avatar
You shouldn´t be forcing the focus ring, you´re going to break the lenses & the AF motor.
It sounds to me like the AF system is simply not finding anything to focus on. It needs something with contrast, and the K200D AF systems is not the best (I have one). Having said that, there may be a problem with the AF, it certainly doesn´t sound like the source of the trouble is the lenses.
Are you saying it always does this even when there is something with contrast directly in front of the lens for it to focus on?
04-24-2011, 01:59 PM   #3
The focus gets "Stuck"... literally. it has nothing to do with contrast.
Applying "force" is a relative thing. If I had to apply significant torque I would not force it... but I need to apply "some" force to get it unstuck.
04-26-2011, 06:32 AM   #4
My K200D does not do that. Sounds like a gear problem. The gear/motor assembly hangs off of the mirror box and looks like a complicated repair. PM me if you would like a parts diagram for the K200D.
04-26-2011, 12:09 PM   #5
I've sent it in for repair via Pentax Professional Services... thanks for the offer.
04-29-2011, 11:32 AM   #6
So I just got the repair estimate. A rather unhelpful document that says the Autofocus will be "repaired or replaced" and it will cost $240... ouch. Might be time for a new camera.
05-01-2011, 10:18 AM   #7
QuoteOriginally posted by cwood Quote
If you buy new - what do you want for the broken K200D? PM me if interested.
camera, dslr, focus, infinity, k200d, lens, lenses, photography, shutter
Sticking focus mechanism on the DA55-300mm lens jlaubza Pentax SLR Lens Discussion 3 04-14-2011 01:04 AM
K200D focus spot grumgrummer Troubleshooting and Beginner Help 2 03-06-2011 09:48 AM
K200d Focus Screen iClick Pentax DSLR Discussion 5 01-22-2011 02:59 AM
K200D focus Screen..... Daveinozbikes Pentax DSLR Discussion 2 05-21-2009 10:26 PM
Pentax DA 18-55mm F3.5-5.6 AL focus sticking Pentaxlvr Pentax DSLR Discussion 1 12-23-2008 01:00 PM
All times are GMT -7. The time now is 09:17 AM. | See also: NikonForums.com, part of our network of photo forums!
