04-26-2011, 03:26 AM   #1
K20D back focus issues
Just been playing with my K20D and a few lenses and discovered that I needed to adjust the AF by between +5 and +10 with most lenses. In some cases even a little more adjustment would have been required to really correct the BF problems. So, 2 questions:
1. Given that I did not have make adjustments for all my lenses (my Sigma 70-200/2.8 was spot on), is BF a camera issue or a lens issue?
2. Is it usual to have to make the sorts of large adjustments that I did?
Cheers,
Qiki
04-26-2011, 08:16 AM   #2
Pauld's Avatar
1. BF is generally a lens issue. Lens are calibrated in factory but it's impossible to calibrate every lens for every type of camera and some fine adjusting may need to be done.
2. Yes
04-26-2011, 06:24 PM   #3
QuoteOriginally posted by Pauld Quote
2. Yes
Thanks for the reply. Since my original post I printed out a focus test chart and went back and made my AF adjustments again. However I found that I needed far less adjustment when testing with the chart (requiring focus from close range) than I needed when doing my original tests (focussing on objects 2-3m away). So, now I'm confused. Do I make the AF adjustments based on the A4 sized test chart, or on 'real' objects a little further away??
Qiki
04-27-2011, 10:05 AM   #4
I adjusted my lens to the focal length that normally shoot with that lens. Worked out good for me.I used Lightroom to help determine most used focal range for each lens.
Mike
adjustments, bf, camera, dslr, issue, k20d, lenses, photography
How do Front/Back focus issues show? DaveHolmes Troubleshooting and Beginner Help 10 01-24-2011 06:28 AM
Front back focus calibration on K20D AKum8 Pentax SLR Lens Discussion 2 08-01-2010 09:06 PM
Front back focus calibration - K20D AKum8 Pentax SLR Lens Discussion 2 08-01-2010 11:20 AM
The mechanics of back focus issues Mister Guy Pentax DSLR Discussion 12 01-30-2009 01:07 PM
Does the K200D have front/back focus adjustment like K20D? raider Pentax DSLR Discussion 4 02-04-2008 11:05 AM
All times are GMT -7. The time now is 06:54 PM. | See also: NikonForums.com, part of our network of photo forums!
