05-04-2011, 10:20 PM   #16
Banned
QuoteOriginally posted by demuire Quote
Question: What are the advantages of shooting in RAW+?
None. You only do more processing with RAW+. It might be useful if you're away and have no access to the Pentax software - then it helps you show your shots on a computer that doesn't have it.
Like others have mentioned already, RAW+ writes both a DNG and a JPG file. The processing needed to create the JPG file is overload compared to the RAW mode. It will impact battery life and it will impact burst rate performance.
I just did a couple of quick tests on my K-7 to see the impact on burst performance. I kept shooting until the internal buffer got filled and then I counted how many seconds it took to flush it to the card. Results:
RAW+: 8-9 shots, 15-17 seconds
RAW: 14-15 shots, 12-14 seconds
I use RAW, I delete bad shots in camera, then I just transfer and convert to JPG the good shots. If you're ever on vacation and people want to see your shots, it might be worth switching to RAW+. But if you don't have a good reason to use it, avoid it. Just remember it exists if you ever can find a use for it.
05-05-2011, 05:31 AM   #17
Don't forget, even if you're on vacation your K-7 is still in work mode and can "develop" your RAW file for you!
05-06-2011, 12:12 PM   #18
Banned
QuoteOriginally posted by jamarley Quote
Yes, but I don't think you can do bulk processing of RAW files in camera - can you?
09-14-2011, 09:17 AM   #19
SlickYamaha's Avatar
Quick question, just to bring up an older thread, rather than start a new one. The 2 biggest downsides to RAW vs jpeg for me are:
1: It takes 3 to 4x as long to preview the photos for editing. When you open a photo in jpeg, it shows up almost instantly, when I open a preview in RAW, it takes 4 or 5 seconds, which becomes very exhausting when viewing 2 or 300 photos.
2: The RAW files dont seem to work when loaded into CS4. When attempting to run "actions" in batch mode, you cant seem to run actions in the RAW format? What I mean is, If I set up an action to apply say a crop to a bunch of photos, then I run the batch, if they are DNG, as soon as it opens, I have to manually adjust the RAW software, hit open, then it runs the process in CS4, then the next photo does the same. Is there no way for "actions" to work in the CS4 Raw software?
I do shoot raw, but sometimes it seems more exhausting then just dealing with the jpegs. Im sure its something I am doing wrong.
09-14-2011, 09:49 AM   #20
lammie200's Avatar
A couple of things to add...
1. If you want to shoot jpg's only, you can always generate a RAW file by pressing the RAW button. Of course it only works for the last shot that you took. So, if you think that you have just taken the best shot of a series, you can save space on your memory card by just converting that one image to a RAW file.
2. Class 10 cards (or there is a faster type of card with an acronym that I can't recall at the moment) helps a lot with write speed. For me it was a no-brainer to get 32mb Class 10 cards.
I shoot RAW+. I like the convenience of using a jpg viewer to check for composition, etc. before delving into PP on a RAW file. Also, the jpg's are so small (at least in comparison to the RAW files) that with a big card space isn't much of an issue. File management is a bit of a headache though. Also, I don't understand why I can't clear the card from the computer. If I delete images from the card on the computer, I get a message on the camera that the image can't be viewed. But I would think that the image would have been deleted entirely. That is a bit of a pain.
09-14-2011, 10:54 AM   #21
In ACR, select all, then everything you do to one, will be done to the rest. If you have Bridge, you can also copy all of your develop settings from one photo to all of your other photos.
https://www.pentaxforums.com/forums/pentax-dslr-camera-articles/121739-those-...ml#post1260216
09-16-2011, 07:07 AM   #22
TER-OR's Avatar
I shoot RAW+ most of the time. For many shots the Jpeg is fine (snapshots, web use), but for those where I need to seriously adjust things I have the RAW. It's just hard drive space, of which I have plenty and can get more if needed. There is a difference between the in-camera JPEG and a RAW converted to JPEG with a good program.
08-19-2014, 08:41 AM   #23
Sudhakar's Avatar
Today first time I tried RAW+ mode and I got two files for each shot. One JPEG and one RAW (PEF) as expected. However, all JPEGs are underexposed by almost 1 to 2 stops. What am I missing here?
p.s: I know this is old thread but relevant to post to get right answer. :-)
08-19-2014, 12:20 PM   #24
ScooterMaxi Jim's Avatar
I find RAW+ beneficial and shoot it most of the time. Almost all images I intend to post or print will come from RAW. The advantage to adding the JPEG is it allows me to keep a record of rejects so RAWs can be discarded to save some space. This is especially helpful when encountering a difficult shooting situation, knowing I won't process the vast majority of shots, yet wanting to keep a record of what could be done better. Also, if I do extensive reworking of a RAW, it is good to have a record of the image as originally exposed.
08-19-2014, 12:56 PM   #25
TER-OR's Avatar
QuoteOriginally posted by Sudhakar Quote
I'd look at your in-camera processing settings. Maybe you're dialing in some compensation?
08-19-2014, 01:01 PM   #26
Master of the obvious
savoche's Avatar
You mean the jpeg is underexposed but not the pef file? Strange. Do you shoot with highlight protection or something?
08-19-2014, 02:40 PM   #27
SpecialK's Avatar
QuoteOriginally posted by SlickYamaha Quote
Just to help out...it's essentially instantaneous in Faststone, which I use expressly for that purpose. PDCU takes forever, however.
08-19-2014, 11:45 PM   #28
savoche's Avatar
...and it would really be better to start a new thread rather than reviving this old one. Most people will respond to older posts rather than yours here
08-20-2014, 12:13 AM   #29
kh1234567890's Avatar
Faststone will show the embedded JPEG unless you change the default settings (Settings -> RAW) or hit the A key when the image is displayed.
08-20-2014, 03:52 AM   #30
Can't see a use for RAW+. It takes perhaps a minute to "extract" the embedded jpgs from an entire card using the Pentax software for quick comparison purposes in a jpg editor. Actual batch conversion may take several minutes. Certainly it can be done while you're making a cup of coffee.
Any image will benefit from some PP even if it is only leveling the horizon (if you have misaligned finders like me) or minor cropping. Any extra work, such as exposure or contrast is normally a small percentage of the total time involved, especially if you consider naming the file, moving it, archiving, etc. Why skimp on a few seconds?
I can, I set the jpeg to have some basic 'glamour' settings and can show the model an image in camera that has a bit of pop to it, rather than the bland raw. It does save a bit of time to give her some prelim images, if you pick the right size and quality they are low res and easy to e-mail etc.
camera, dslr, image, jpeg, lot, pentax, photography, preview, previews
Why do RAW my RAW images not look great... pjthiel Digital Processing, Software, and Printing 23 05-17-2011 07:00 AM
K5 raw DNG files borked by Aperture/Apple Raw upgrade? filmamigo Digital Processing, Software, and Printing 4 02-22-2011 04:51 AM
How to save stitched RAW files to a RAW file? HermanLee Digital Processing, Software, and Printing 7 07-09-2010 05:51 PM
[K10D RAW+]Exposure difference between RAW and JPEG sterretje Pentax DSLR Discussion 9 04-13-2010 02:06 AM
RAW duplicate images - saving as RAW files jpzk Digital Processing, Software, and Printing 17 02-15-2010 07:01 PM
All times are GMT -7. The time now is 07:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
