11-01-2007, 07:40 PM   #1
When and how to use SR and how effective?
Being new to the K10d - I wanted to find out more about SR. When and how to use SR basically? How effective is SR?
Also for K10d owners - if you move your camera side to side does something move inside your K10d? I noticed this even when the camera is powered off. I imagine its that whole floating mechanism for SR moving around but I could be wrong.
Thanks.
11-01-2007, 08:18 PM   #2
SpecialK's Avatar
You shouldn't use SR on a tripod or when panning at slow shutter speeds. The K100D turns it off if you use any self-timer function or the remote release, and I'm guessubg the K10D is the same. Check the manual.
It's hard to put an exact number on the difference in f-stop you can use with SR as there are so many variables. I've gotten good shots at around 1/4 sec with wide to normal lenses. I try to be at 1/250 or faster at the long end of a 70-300, though.
11-02-2007, 12:58 AM   #3
axl
QuoteOriginally posted by Takman Quote
Thanks.
As for the moement in camera. That's the SR itself. When camera is OFF the sensor with it's base is loose inside so when you lean your camera sideways you feal and hear it moving. No worries about it, it's OK. When you power it ON (with SR ON) the magnetic force starts working and that's how it all works, (with SR OFF) it'll lock in firmly so you can't hear or feel it anymore...
As for using it: apparently most effective way is to press shutter half way (that'll activate SR) wait for 1/2 - 1 sec (that enables gyroscopes to detect camera / your shake) and shoot...
How effective it is?!? it depends on all circumstances, I can say it never let me down, if I don't expect miracles, and I have quite shaky hands.... genral claim though is 2-3 stops
11-02-2007, 01:00 AM   #4
axl
... The K100D turns it off if you use any self-timer function or the remote release....
Didn't know that...
But then I can't honestly say I really paid attention to manual... I guess I used man-like approach - try to work it, if it doesn't read manual
11-02-2007, 01:33 AM   #5
Mike Cash's Avatar
135mm lens, handheld
1/6 second exposure:
WITHOUT SR
WITH SR
Using the "shutter speed at or faster than focal length" rule of thumb:
1/125 (closest to rule of thumb)
1/60 = 1 stop
1/30 = 2 stops
1/15 = 3 stops
1/6 = 4 stops
So I got about 4 stops extra leeway from SR on that impromptu test. You can always count on two stops, I should think.
11-02-2007, 02:32 AM   #6
I find the SR very effective - personally I leave it on pretty much all the time & don't give it much thought (unless using a tripod)
simon
11-02-2007, 04:10 AM   #7
Finn's Avatar
One thing I've noticed is that there is a slight delay (maybe 1/2 sec) after you half-press the shutter release before SR engages, so if you are just quickly snapping away it may not engage before you take the shot. You can tell by the indicator icon in the viewfinder. Just something to keep in mind.
11-02-2007, 04:35 AM   #8
See a good and systematic test here as a reference:-
Digital SLR and Lens Review: Testing K10D and K100D Shake Reduction
11-02-2007, 05:30 AM   #9
Lowell Goudge's Avatar
if you want to get a good idea of shake reduction, what it can do, and what still remains, take a look at the following thread, and the two photo's I posted.
https://www.pentaxforums.com/forums/general-pentax-photography/13308-do-you-a...tly-blurr.html
First is with *istD and 500mm lens plus flash.
Second is K10D with shake reduction and a 300mm lens,
The flash burst is extremely short (probably 20-30 microseconds, or an equivalent of 1/50000 of a sceond shutter speed)
The flash image is totally forzen, and very sharp. The image iwth shake reduction is not too bad, but...
Also note that the image with shake reduction has a second problem. I use a 1.4x TC with the 70-200mm lens used in this image. Pentax does not compensate for the change in focal length due to the TC when it reads focal length from the lens, as a result SR is set to the wrong focal length.
11-02-2007, 06:24 AM   #10
That's what I have said in my old K100D review (the SR section) that proper shooting techniques are always preferred over using SR! (Direct link: RiceHigh's Pentax K100D Full Review )
The source of this problem is just that there is no original Pentax AF tele-convertor ever made and available. Otherwise, the focal length lens data should have been able to be converted all together instead of a lens data "loopthrough".
11-02-2007, 06:45 AM   #11
QuoteOriginally posted by RiceHigh Quote
I am using sigma lens and TC for the shot posted. Same problem exists however if I use my Pentax AF TC and pentax lenses.
Pentax has been requested to provide either boot up option for TC like it does for manual lens focal lenght, ot special function. So far, nothing.
11-02-2007, 07:37 AM   #12
Pentax has never made any true "AF Teleconvertor". They had only a Tele AF Convertor 1.7X, which was designed to convert MF lenses with AF function, by focusing inside the convertor with limited AF capability.
The only available AF Teleconvertors in the market for Pentax mount are made by Kenko and Sigma only and you can find Tamron re-badged Kenko once a while (which I have one). The Kenko AF TC do not convert anything, neither the f-number nor the focal whilst the Sigmas convert the aperture (but not focal neither). Both will work correctly for exposure and metering though as the set and maximum aperture info and light metering values are cancelled out (and yet the correct exposure value is obtained again). But as you said, since the focal data is not multiplied, the SR will not function correctly (but partially from my experience).
camera, dslr, k10d, move, photography, sr
Is SR effective? flyer Pentax DSLR Discussion 55 04-14-2010 11:41 AM
Pentax SR effective when panning! falconeye Pentax DSLR Discussion 12 03-26-2008 09:32 AM
is SR effective simons-photography Photographic Technique 24 03-22-2008 03:48 AM
Quality, Effective Memory Card dales Pentax Camera and Field Accessories 10 12-12-2007 06:04 AM
NEW Pentax rebates effective TODAY! macdaddy Pentax News and Rumors 13 05-03-2007 12:45 PM
All times are GMT -7. The time now is 04:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
