Originally posted by JamesD I see that one can set through the menu the dust reduction vibration to be activated when the camera is switched on. So I take it that by default it is "off" and one must set it. Or is the default that it turns on when we switch the camera off? I'm confused about this so could someone enlighten me? And is setting the dust reduction to be activate when the camera is switched on... overkill... since I tend to switch the camera on and off frequently during a day of shooting? Thanks again.
The default is "off". I have never felt the need to initialize it to "on". When it is "on", it will 'dust bust' at power-on. That is when it would do the most good, not when the camera is deactivated.
I have noticed that I get a lot less dust with the K10D than my older Ds bodies. Maybe it is due to that new CCD coating they put over the sensor? With the DS, I'd have to de-dust about every few weeks; in the year I've had the K10D, I've only needed to run the dust-buster about three times total. Only when I notice specs on my images.
Since dust doesn't seem to be as big of a problem, after considering turning the dust-buster to "on" at startup, I elected to just leave it "off", and save the battery power for picture taking.
