Originally posted by Hefa so what should I assign green button to?
To just stop down you assign Green Button to Green Button and then Action in M mode to P Line.
If you want to see a preview to adjust exposure before you shoot then set green Button to Digital Preview. That just gives you the image with no info but you see the settings the camera has for speed and ISO in the LCD as usual - adjust before you try another green button press. If you want to see how far what you have chosen is "out" set the Green Button to Optical Preview. That gives you how much over or under exposed the image will be in the viewfinder. Keep holding the green button down and you can adjust the exposure and see the numbers change.
1st method is much easier - Green set to green and Action in M mode set to P-Line. Then it chooses the shutter speed for you after stepping down. Then review the image and decide if you want to change the aperture and try again. It makes it "semi-auto" but you can still learn what combination of shutter speed and aperture you need or want.
