Originally posted by jlaubza Hi, I'm sorry to say that you bought the wrong camera! You need a camera that has leds that light up in the VF - the KX hasn't got these - You must listen for the beep sound that tells you the camera has focused or look for the six sided shape to light up at the bottom of the VF.
The problem is not that, I do not need the LEDs in vf because I only shot with the center spot af point.
Originally posted by jlaubza If the camera can't focus, then the lighting conditions are really too dark for a picture without a flash.
with high ISO, wide aperture , and steady hands (or a monopod), it's never too dark to shoot without flash, but if i can't focus correctly I can not take advantage of the good performance in low light of the k-x
Originally posted by jlaubza Perhaps a small but bright LED battery torch/flashlight can be helpful - you switch it on and hold it next to the camera pointing at the subject. The LED pointer also works but if it shines in a person's eye, you may be creating a problem for them.
I was seriously thinking about a solution of this type for now, I would like to try with a red laser with a diffraction grating applied, the light so widespread should not be so dangerous, also it would be possible to focus in areas with no or poor details
