Originally posted by Marc Sabatella ??? I don't understand what you mean. I just mean, given lenses with equivalent FOV, you can stop down the lens on more stop on FF to get the same DOF as the lens on camera APS-C, whereas you can't open the lens up on APS-C any more than wide open, so you'll never be able to match the shallowness of the DOF you could get on FF. this shouldn't be a controversial claim at all; it's pretty self-evident really.
You can't stop down the longer lens to achieve the same hyperfocal distance of the shorter lens. As Bob Atkins says:
Close to the hyperfocal distance, the APS-C crop sensor camera has a much more than 1.5x the DOF of a 35mm full frame camera. The hyperfocal distance of a APS-C crop sensor camera is 1.5x less than that of a 35mm full frame camera when used with a lens giving the same field of view.
That said, you can always use the shorter lens and crop.
Quote: The one counterargument would be if someone were to say, but what if the lens on were already stopped all the way down. Then I'd have to say, OK, you got me, if you are shooting your APS-C lens stopped *all the way down* (presumably, your shot is being lit by a supernova or you have an extremely steady tripod, and you have never heard of diffraction and don't realize this is not something you'd normally ever want to do), then indeed, you couldn't go an extra stop on FF. So you'd have trouble getting a picture quite so badly ruined by diffraction and motion blur just for that extra last bit of DOF. But I pretty guarantee this is not a concern 99.999999999999% of the time, as compared to the inability to get a sufficiently shallow, which does actually come up. Not all that often in my world, but often enough overall to be at least worth a mention, and again, it really shouldn't be the slightest bit controversial.
Think about it. Sunny sixteen = f16 at the reciprocal of the aperture. So ISO 400 @ f22 = 1/200 sec, no supernova or tripod required, just sunshine and the 'ol human tripod. So all of your hyperbole aside... And while diffraction DOES reduce resolution and contrast, I promise you can make a pretty good 8x10 if you start with a reasonably high-contrast lens. Of course, personally, I'd do focus stacking or pano-stitching or both, and exceed the image quality of a MF digital camera OR a FF. But if I were shooting a crowd of folks and absolutely had to have the f22 DOF, I wouldn't hesitate to do it; better the shot you get than the one you miss, eh?
Quote: Pixel pitch is not very significant in determining IQ; that's largely a myth. Overall sensor size is the *far* greater determinant.
You're mixing your metaphors. Larger sensor sites mean higher signal-to-noise ratio, it's true. In the GENERAL case, all things being equal, larger sensors == better IQ. In the specific case of macro or long telephoto, as long as I light the pixels enough to beat the noise threshold by a sufficient percentage, then higher pixel density== greater detail captured (provided, of course, that my LENS is capable of resolving the higher detail).
I'm not making the general claim that higher pixel density == better IQ; I'm making the claim that, in lighting conditions that supply sufficient signal-to-noise ratio, more pixels==more detail. So if I'm not shooting high-ISO macro or long telephoto, the higher pixel density DOES translate to higher detail, to the limit of my optics. And if optics are the limitation, the APS-c will resolve the same level detail as the FF.
Quote: On the other hand, the FF sensor is "likely" to have more pixels than the APS-C sensor, all else equal, and of course, requires less magnification for a given print size. Without knowing the *specific* lenses and *specific* sensors involved, it's going to be tough to predict which combination (FF w/200, APS-C w/135) is actually going to be sharper. I wouldn't presume to make generalizations there.
I would say that statement should be wrapped up and bronzed. When you talk about FF vs APS-C, you're talking about hypotheticals all the time, and any specific pairing of cameras and lenses might turn up a different result.
The sensor in the K-5/D7000/sony-alpha-something has put APS-c on a fairly similar footing with FF for noise and DR. I am well aware that this will change when the sensor technology in the K-5 migrates to FF cameras; I'm talking right now, with the current cameras.
When the D800 hits with ~18 stops of DR and 22 mpixels, I'll cheer it on. I won't switch, because I love Pentax glass, but I'll certainly grant that it's got significantly better IQ.
The remaining "advantage" of FF is *purely aesthetic*. "I like portraits with virtually no DOF" is a great recommendation for a FF camera, but the general statement "Portraits with very low DOF are categorically better than those with greater DOF" is absurd on the face of it, and required to call the lesser DOF of FF (at FOV and distance) "better".
I've never argued that FF doesn't present better IQ, all things being equal (right now, they aren't). I *have* argued with the assertion that the differences in DOF@FOV create some pixie-dust advantage for FF; If you *like* it better, that's all good. Asserting that it's OBJECTIVELY better is just absurd.
I do miss the viewfinder, though.
