Originally posted by m3hxe Hi all im looking at buying a Pentax K10d ond ebay. It has 7764 shutter actuations on it.Is this a low count for the camera? What count does yours have?
My 3.5 year old K10D has over 30K+ shutter actuations and is still going strong, so 7764 isn't too bad and it sounds like the owner hasn't taken an awful lot of photos with it.
Originally posted by Laurentiu Cristofor The shutter count gets reset at each 10000 shots. I believe I reset it twice on my K10D and it still works great. Make sure you read the actual shutter count from the EXIF file of a new image, not the number from the image filename - there are tools for reading the EXIF data that someone else may recommend - I never used them, I just know they exist.
The
filename count clocks over at each 10000 shots but the shutter count doesn't clock over. The K10D names it's files IMGPxxxx or _IGPxxxx (where xxxx is the file number) depending on which colour space the camera is set to use, so when you get to IMGP9999, the next photo is either IMGP0000 or IMGP0001, I'm not 100% sure which one it is, but that doesn't change the fact that you've added 1 to the actual shutter count, not taken away 10000. That is why looking at the filename of a photo from a camera is not a very accurate way of determining shutter actuations.
I use photome and it does list the shutter count as a data field. Exiftool also does it, but I prefer the GUI of photome.
