05-24-2011, 03:36 PM   #1
How to clean ?salt? out of the shutter release button?
I took my Pentax K7 out in my kayak in the bay. I got some limited splash on it which did not appear to impact anything.
However, since then, my shutter release button sort of sticks half depressed... and the on/off switch is a bit more difficult to turn than it should be...
How would you suggest cleaning this beyond sending it in for a repair?
Thanks,
Javaslinger
05-24-2011, 04:00 PM   #2
Luckily, you have a K-7, which can withstand a decent washing under the sink. Observe. Watch it all the y to the end.
*Disclaimer* Don't blame me if by some freak accident this does in your camera. But it should be able to more than take it. Many time's I've washed my K10, K20, K-7 and K-5's under a gentle flow of tap water. Helps with salt water for sure.
05-24-2011, 04:59 PM   #3
Ex Finn.'s Avatar
Gentle! rinse with the kitchen sink sprayer might do it.
Took care of spilled chocolate-milk on my K7.
05-24-2011, 06:18 PM   #4
Ratmagiclady's Avatar
QuoteOriginally posted by Ex Finn. Quote
I'll point out that not all kitchen-sink sprayers are capable of 'gentle.' Mine's actually good for washing pots, but it has *recoil.*
05-25-2011, 05:15 AM   #5
Diluted alchohol/Spirit might help.
05-25-2011, 09:22 AM   #6
QuoteOriginally posted by Ratmagiclady Quote
True! And even most sinks at low pressure have quite a bit of weight behind that water. Thanks for reminding me. What I usually do is fill a cup from the tap, then I can pour is much more gently on the camera over the sink.
05-25-2011, 06:15 PM   #7
Ex Finn.'s Avatar
You should be able to regulate the sprayer "force" by running the tap simultaneously. At least in a house-hold sink, don't know about commercial ones.
Yeah, recoiling is not desirable in this case.
05-25-2011, 08:51 PM   #8
True 'nuff: what we have here has some kind of special valve to it that actually gives you a pretty high-pressure stream, (Useful, actually, but makes kind of a big 'thunk' when you depress the sprayer, and it's either on full blast or off. )
05-25-2011, 11:27 PM   #9
Just use water
If it is really salt in the release, it should dissolve in plain water. Maybe you have some sand in there. If you do you might try gently using a soft toothbrush to dislodge it.
camera, dslr, photography, release, shutter
Broken shutter-release button on Pentax K-x fashionista20100 Troubleshooting and Beginner Help 5 04-26-2011 06:25 PM
K-x sticky shutter release trigger/button alaricxyz Pentax DSLR Discussion 8 03-31-2010 04:56 AM
Pentax Me is missing its shutter release button iridescentstripes Pentax Film SLR Discussion 3 01-12-2010 05:37 PM
K10D shutter release button not working well . Any ideas lesmore49 Pentax DSLR Discussion 6 07-19-2009 10:48 PM
Faulty shutter-release button? Mann Troubleshooting and Beginner Help 6 05-30-2009 09:54 AM
All times are GMT -7. The time now is 07:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
