05-29-2011, 01:24 AM   #1
i_trax's Avatar
K-X stop down metering problems with fast lenses
Hi, My "new" Auto Soligor 135mm 2.8 , K mount SN248xxxx with silver aperture ring will not work correctly with stop down metering at 2.8 and next click ( between 2.8 and 4 ),
this seems to only occur outdoors in bright daylight.
the image is well overexposed , practically just white screen.
if I switch from M to Av everything is fine, in lower ambient light everything is also correct.
So is it K-X or the lens? anyone experienced anything like that?
kind regards
jack
05-29-2011, 08:53 AM   #2
Marc Sabatella's Avatar
What ISO are you using, and what shutter speed are you getting? My guess is, in bright light and f/2.8, your camera just can't get a fast enough shutter speed to get a well-exposed picture. Be sure to have ISO turned down as low as it goes - and that means turning off any artificial dynamic-range-enhancing options that restrict your ISO range.
05-29-2011, 09:11 AM   #3
Some manual lenses do tend to trick the light meter (K/A 15mm for example)- try using spot metering or compensate manually.
07-27-2011, 06:00 AM   #4
i_trax's Avatar
I do not experience anything like that with K7, the same lenses, the same situation although we do have Winter here in Perth right now , I might recheck it during next Summer
camera, dslr, k-x, photography
Auto Lenses on Pentax Kx..stop down metering..HELP CLYNN0928 Pentax DSLR Discussion 7 11-10-2010 03:54 AM
stop down metering? jonhock Troubleshooting and Beginner Help 8 01-01-2010 04:00 PM
K-x Stop-down metering with m-42 lenses Bazwell Pentax DSLR Discussion 8 11-20-2009 12:57 PM
K10D, SMC-M lenses, stop-down metering J2R Pentax DSLR Discussion 10 05-22-2009 03:26 AM
Stop Down Metering with K20D and Tamron SP Lenses petez Pentax DSLR Discussion 39 04-05-2008 08:53 PM
All times are GMT -7. The time now is 11:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
