11-08-2007, 05:26 AM   #1
ISO Options?
Hello, I just got my K10D and I've had a quick look through the manual but I'm unable to find a way to increase ISO options. Does the K10D only have ISOs 100, 200, 400, 800 & 1600 or are there also inbetween ISO settings like ISO125? I have done a search on the forum but can't lock an answer down.
Tim H
11-08-2007, 05:37 AM   #2
Lowell Goudge's Avatar
QuoteOriginally posted by Timbuctoo Quote
Look at the functions for EV Steps, first page of custom settings. this can either be 1/2 or 1/3 stops this controls everything, shutter apature and ISO.
Tim H
Once you have set the EV Steps, press the FN button and using the 4 direction selector select ISO, you will see nominal 100,200, etc numbered, with divisions in either 1/2 or 1/3 stops depending on EV steps setting, you can pick any intermediate ISO as long as it is either 1/3 or 1/2 of a stop from a nominal ISO
11-08-2007, 05:37 AM   #3
I don't have my k10d with me right now, but there is an option to set iso to step as ev steps(1/2 or 1/3 stop). It is in the custom setting menu.
Edit: oops, Lowell is a faster typer than me!
11-08-2007, 05:42 AM   #4
You can also set a custom function to utilize one of the scroll wheels in conjunction with the OK button, to set ISO without going through the Fn menu.
11-08-2007, 06:04 AM   #5
mattdm's Avatar
QuoteOriginally posted by roscot Quote
Which has the awesome side-effect of making it show up in the viewfinder all of the time.
11-08-2007, 06:10 AM   #6
Ok, thanks for that I now how more than enough ISO choices. I guess after using a Konica Minolta 7D for a number of years you just get used to that setup. I'll have to read the manual more carefully. Thanks again.
Tim H
11-08-2007, 09:40 AM   #7
And mattdm adds,
QuoteOriginally posted by mattdm Quote
Yeah, that's neat. But I have played with these settings a bit and find them confusing. I shoot mostly in M or TAv. I really like having the two e-dials control shutter (front) and aperture (back). The option to control ISO with an e-dial doesn't work (or make sense) in TAv, and doesn't work in M (where it would make sense, if the e-dials weren't already being used for something else).
Am I missing something? Roscot mentions using the "ok" button. What's the ok button got to do with anything here? I have the back e-dial set to control ISO in Tv mode. I don't have to touch the OK button to change the ISO, as far as I can tell.
Will
11-08-2007, 09:54 AM   #8
mattdm's Avatar
QuoteOriginally posted by WMBP Quote
And mattdm adds,
Yeah, it's a tip that's only useful in Av and Tv modes.
On the K100D, the OK button can be configured to temporarily show ISO in the viewfinder. The K10D doesn't appear to have this option. (Why there isn't an option to just always show it is beyond me.) You can also make the OK button return the selected focus point to center. On the K10D, you can make the AF button do this, but I kind of wish one could do it with the OK button instead because it makes more intuitive sense (what with being in the center of the arrows and all).
11-08-2007, 09:55 AM   #9
You can set the ISO by pressing and holding down the OK button while turning the front dial. The camera also displays the current ISO while pressing the OK button, both in the viewfinder and on the top display. It’s not in the manual as the function came in one of the early firmware updates. (This goes for the K10d)
11-08-2007, 10:26 AM   #10
Yes, I agree, that would be useful. One of the few user-interface foibles of the K10D.
Will
11-08-2007, 10:31 AM   #11
QuoteOriginally posted by Gimbal Quote
Wow, great tip. Somehow I've missed that. Thanks!
Will
11-08-2007, 10:32 AM   #12
The K10D has had that feature since day 1 (showing ISO with Ok button). And I just tried it with firmware 1.30 and it still works (and you can change the ISO with the front dial while Ok is pressed).
11-08-2007, 10:36 AM   #13
Edit: Post removed. answers came in while I was typing.
11-08-2007, 10:50 AM   #14
QuoteOriginally posted by RBellavance Quote
I was agreeing with Matt when he said: "Why there isn't an option to just always show it is beyond me."
It's good to know that I can punch the OK button to SEE the ISO, and can change it without going into the Fn screens. But Matt's right: it should be visible in the viewfinder all the time, or at least that should be an option.
Will
11-08-2007, 12:26 PM   #15
Miserere's Avatar
Will
If you have one of the e-dials set to control ISO, then the ISO will appear permanently...in place of the # of shots left! Is it too much to ask to have both?
camera, dslr, iso, k10d, photography
Suggestion Add more options to ISO drop-down menu dgaies Site Suggestions and Help 2 10-31-2010 07:51 PM
K-r vs. K-x ISO samples (or return of the ISO flower!) devorama Pentax K-r 31 10-29-2010 02:05 AM
[Auto-ISO] so, is the K5 and Kr brave enough to use max iso? Reportage Pentax K-5 & K-5 II 13 10-24-2010 03:30 PM
Default ISO 200 vs ISO 100 joodiespost Troubleshooting and Beginner Help 6 01-09-2010 05:50 PM
Tests iso 200 to iso 3200 with k100d Deni Post Your Photos! 0 06-20-2007 05:17 AM
All times are GMT -7. The time now is 04:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
