Originally posted by FishrOfGrizz Oh yeah, Image Tone. Got it. I was going to post a question to ask how or to what advantage this was used. I hadn't recognized it as Natural or Bright. So, as in the Bright setting, does this more or less override the need for Contrast or Sharpness adjustments with the slide bars or does this add even more Contrast and Sharpness to whatever you've already adjusted - if you had adjusted?
I think you need to do a set of trial shots. I am quite sure that if it is set to bright, you can still boost saturation and contrast also, What I can't answer without doing testing is what the "neutral" settings of contrast and saturation correspond to the "Bright" setting with no additional contrast of saturation
