Originally posted by lordson I know my K100D Super has shake reduction, but does it do anything at all??
i think it does jack all. i've pretty steady hands and my elbows are pressed right up against my body, even when i lean against a wall photos can still come out shaky
what the hell is the Shake Reduction function even doing? is my camera broken or something?
heres a few samples, the first taken in indoors low light at 50mm, and second outdoor nighttime at 200mm. maybe .5s shutter time nothing too long
how much does the Shake Reduction actually reduce camera shake?
i'm getting a tripod soon, but when going on a trip you just can't bring a tripod along
cheers
Well, as quoted by other, since your first picture is taken @139mm (equivalent 24x36) you could expect being able to go down from the 1/125s to 1/15s (around 3 stops) with SR. Your chosen speed of 1/8s is one stop under that and is at the very limit of the SR specs, hence the slight blur.
The second one is a good one: with a 65mm lens, you should be able to go from 1/60s to 1/8s or so but 1.5s is almost 4 stops below.... a tripod is your best friend here
SR really works wonders, here's a shot from the galery I took last saturday using the DA 12-24 @1/4s and it is tack sharp but I don't expect getting away with sub 1 second shots, even with a wide angle.
