06-06-2011, 09:13 PM   #1
k10d lenses
So i went to look at a k10d digital slr today and brought some of my old Pentax lenses with me they consist of a smc pentax-m 1:2 50mm, smc pentax-a 50mm 1:1.7 ,smc pentax-a 1:2.8 this one mounted on the camera but it would not take a picture and last was a Quantaray 55mm af 100-300mm this lense mounted and would take a picture, and actually took a great picture. I guess the question i have to ask is will these other lenses work for me and do i have to do something different with these non af lenses when i mount them to the camera such as a manual setting on the camera itself.
Thanks
John
06-06-2011, 10:12 PM   #2
Lens on K10D
Yes they fit, yes they work, however I have not done it yet, and there IS a thread that can tell you how on this site. Too much for me to attempt yet, as I have some Manual lenses to try on my K10D also..
06-06-2011, 10:19 PM   #3
AOShep's Avatar
Unless the lenes are actually broken they should have worked. The A lenses, with the aperture ring need to be set to A. For M and A lenses you need to set in the menu "using aperture ring" to 2. With the M lens the camera will not display the f-stop. You will get F--. To check your exposure press the green button or use DOF preview to check exposure settings. I am sure the aperture ring setting is why the camera would not respond to those lenses.
06-07-2011, 08:48 AM   #4
Marc Sabatella's Avatar
See the sticky thread at the top of the beginner's forum for info on how to use manual lenses. Takes much longer to explain than to actually do it; the process is really quite simple.
06-07-2011, 10:04 AM   #5
k10 lenses
Thanks everyone for their input. So i guess i will go back and buy the camera. Saying i do decide to buy some other af lenses what would it cost for a wide angle andd just a regular lense .
Thanks Again i am sure i will have lots of other questions once i start using the camera
John
06-07-2011, 10:41 AM   #6
That depends on what you mean by wide angle! It would be good just to start out with the Kit lens, 18-55mm. If the camera you're buying doesn't come with one, they can be found in the marketplace for around $50. If you are familiar with the angle of view of the lenses you mentioned on a traditional film camera, for reference 18mm on digital will give about the same photo angle of view in the final product as the 28mm lens you referenced above. If you want something wider than that, the prices start to go up fairly quickly!
50mm, af, camera, dslr, k10d, lenses, pentax-a, photography, picture, smc
For Sale - Sold: k10d + DA* 16-50 f2.8 + MORE LENSES (US) enrod666 Sold Items 4 09-24-2010 02:40 PM
How to use M and K lenses in AV mode on K10D? yyyzzz Pentax DSLR Discussion 9 01-27-2010 01:58 AM
k10d not stopping lenses down katanaismybike Pentax DSLR Discussion 7 10-22-2009 05:29 PM
All times are GMT -7. The time now is 01:07 PM. | See also: NikonForums.com, part of our network of photo forums!
