06-13-2011, 07:54 AM   #1
dark pics from tv settings
hi all,
was at a king cobra santuary on saturday taking loads of pics,later in the day they put on a show which needed a faster shutter speed so i used the tv setting thinking that'll be fine,when i put all the pics on the laptop all the pics on tv setting was really dark.i had taken pics in the same place earlier which was fine,so my question why was the pics dark and when i was taking the pics they did'nt look dark for the few secs they show on the screen.
so its long winded but just trying to explain what happened.
cheers
06-13-2011, 04:00 PM   #2
Show us an example of each complete with EXIF. One that worked in that setting, and one that didn't. Chances are, you had the shutter speed so high that the aperture could not compensate and pegged itself wide open. Was the aperture number Flashing? Did you use Auto ISO or did you have it fixed at some number? Which camera?
06-14-2011, 07:33 AM   #3
pics are now in my album,first two are regarding problem + others i thought came out really well.
hope it helps
06-14-2011, 08:16 AM   #4
SpecialK's Avatar
The first dark shot @ 1/1600 is 4-1/2 stops underexposed from the first good one @ 1/60.
Unrelated to your problem, but I recommend not using spot-meter.
06-14-2011, 08:20 AM   #5
your speed was way too fast and probably too fast to get a "correct" exposure at F4 and ISO 400 so it underexposed. I assume F4 was as wide open as the lens would go. You needed a higher ISO and could have possibly got away with a slower shutter speed. You should have got some sort of indication that the shot was underexposed while shooting.
Your other shots are a bit all over the place too. Don't use spot metering unless you really know how to use it and what it does.
06-14-2011, 09:10 AM   #6
KCS 360
Doesn't have anything to do with spot metering. Simply put, the shutter speed is way too fast for the situation. In Tv, you choose the shutter speed, the camera picks the aperture. Most likely as I suggested before, the camera pegged the aperture wide open, flashed the number, and probably gave you a flash warning (usually shows as a lightning bolt on the left side of the viewfinder). If you have auto ISO enabled for the semi auto modes, then boost the upper limit. If you have set it manually, set it higher.
In other words, the camera did exactly what you told it to do.
Exposure, Exposure, Exposure. Shutter speed, Aperture, ISO. All 3 must be accounted for.
06-14-2011, 10:00 AM   #7
QuoteOriginally posted by JeffJS Quote
Has anyone said it has? 2 posts have noted spot meteing was used which is not recommended unless you know a specific tone you want to meter for or take a series of tonal readings to weight yourself. Using it without that knowledge can lead to under or over exposure but the obvious main cause, in this case, was too fast a shutter speed and too low an ISO as was mentioned.
06-14-2011, 12:47 PM   #8
thanks for the replies,why did'nt the pic look dark on the screen straight after i took the photo?.
06-14-2011, 04:04 PM   #9
twitch's Avatar
QuoteOriginally posted by srandall47 Quote
You were in "live view" perhaps?
06-14-2011, 11:26 PM   #10
No,was'nt in live view,when pic shows on screen after you've taken it,think i've got my camera set 3 sec,pic was'nt dark then?
06-14-2011, 11:33 PM   #11
twitch's Avatar
Are you in bracketing shooting more perhaps?
06-15-2011, 09:25 AM   #12
Getting confused,what is bracketing shooting?.
06-15-2011, 12:57 PM   #13
Apparently not. Bracketing, You take one photo at one exposure. Then you take another of the same thing at a different exposure (less light) and take a third at another exposure (more light). It's something film shooters do a lot of because they cannot See what is on the film before developing it. It's sort of an insurance policy.
Check your screen settings. Do you have the screen brightness dialed way up? (It's in the settings menu).
06-15-2011, 08:49 PM   #14
Marc Sabatella's Avatar
If it's too dark on your computer, it was too dark on your camera screen. You probably just forgot which picture you were looking at.
camera, dslr, photography, pics, tv
Newbie! K20d dark photos & settings rtrox Troubleshooting and Beginner Help 16 11-09-2010 10:53 PM
Do camera settings affect RAW pics when opened? harleynitelite Troubleshooting and Beginner Help 5 12-16-2009 11:27 PM
Best K-M settings for taking fall pics rajdori Troubleshooting and Beginner Help 3 10-18-2009 10:12 AM
I'm unhappy with K-7 settings. Help me custom the settings like k20. netuser Troubleshooting and Beginner Help 16 09-01-2009 08:39 AM
Dark spots in pics explr1 Photographic Technique 5 10-17-2008 12:00 AM
All times are GMT -7. The time now is 04:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
