Originally posted by psychdoc Shoot JPEG+DNG at the same time.
Then do your adjustments on the RAW picture...
While this is a useful way of thinking, it also makes it easy to miss the point. For *msot8 images, it is not reasonable to expect you'll do "better" than the JPEG if you like the JPEG. It's also not reasonable to expect it will take any effort at all to get results just as good as the JPEG. In other words, shooting RAW is neither better nor worse than shooting JPEG for most images.
The point of RAW is for images where you might have planned to do editing either way. For those images, you should find it takes *less* effort to get results you like with RAW, and you'll never do quite as well with JPEG. If you find it takes more work with RAW, you've got the wrong software.
In other words, RAW is about taking *less* time doing processing. If you expect to do zero processing, then RAW cannot ever provide any advantage. Only if you think you might do processing even on the JPEG would shooting RAW ever have an advantage.
