06-16-2011, 08:07 PM   #16
RXrenesis8's Avatar
Given the spillover of the highlights into the black area I'd say that either the trailing curtain is triggering early (doubtful) or the mirror is not lifting properly (my guess).
Edit: It definitely looks like the mirror, with a 3 second exposure the trailing curtain problem does not make much sense.
It does not appear to be the card, if it was the picture would be cut off in a single row of pixels.
Try this:
1.) Put the camera(s) in mirror lock up mode.
2.) Press the shutter release button, you should hear the mirror flip into the up position and you should not be able to see through the viewfinder. If you can see through the viewfinder, or if you do not hear the mirror moving you've identified the problem.
3.) Press the shutter button again to take the picture.
4.) Report back with your results!
Also: try shining a flashlight through the viewfinder and taking a picture.
camera, dslr, half, images, k-7, k10d, photography
Black specs on images Pritch Pentax DSLR Discussion 4 08-23-2010 09:04 AM
K100D - Images are black Aussiepentax Pentax DSLR Discussion 9 12-28-2009 09:13 PM
New K10D sometimes shots black images. rcl Pentax DSLR Discussion 7 03-23-2008 01:07 PM
New K10D, starting to record "Black" images intermittently mhuterer1 Pentax DSLR Discussion 13 12-28-2007 12:16 PM
All times are GMT -7. The time now is 03:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
