06-16-2011, 08:35 AM   #1
HELP ME! Black images
First time posting here. PLease bare with me.
Last two weeks my k10d broke down. First it was half black half coloured picture. After that, only black blank images were produce.
Now, i just bought a second hand k-7.
All good for 3 days, suddenly just now, the same thing happened. The hell!
Live view all black.
I used the same card n lens during both incidents. Swapped cards n batteries still the problem is there.
Help me! Ive tried reflashed the firmware in k10d. To no use. And i doubt it would do good for k-7.
Pentax have failed me twice. My wedding job is next week.
06-16-2011, 08:44 AM   #2
Is the lens cap off and the aperture open? :P
06-16-2011, 08:56 AM   #3
Yes. :ugh:
One thing ive noticed is that, in both bodies, when i put the "Sensor Cleaning" on. I can see both sensors are covered with some kind of black layer. "Window`s blind" look alike.
It looks like that things is stuck onto the sensors.
Anyway to manually released it?
Btw, what do you guys think the main cause of this prob? The lens or the sd card?
06-16-2011, 09:05 AM   #4
What type of lens are you using and what type of sensor cleaning media have been used ?
06-16-2011, 09:55 AM   #5
QuoteOriginally posted by abgsiddiq Quote
Yes. :ugh:
Looks like the shutter that covers the sensor may be jammed.
06-16-2011, 10:34 AM   #6
Yes. :ugh:
QuoteOriginally posted by manishved Quote
What he said. That's the shutter you are looking at. It should be opened to expose the sensor in cleaning mode. It is VERY strange that it would happen with 2 different cameras at the same time. What have you been doing with these cameras?
06-16-2011, 11:18 AM   #7
K57XR's Avatar
Have you tried different lenses? Is there actually a file being recorded (JPEG, RAW or both?) If so, can you PP the RAW and increase the exposure to as high as possible? I'm curious if photo is actually being shot but severely under exposed and coming out black.
06-16-2011, 01:53 PM   #8
And as K57XR said -
I don't have any experience with this type of problem.
However I am wondering if you have used another brand lens that
extends too far into the camera thus causing shutter damage in both
cameras? What happens with the kit lens if you have one?
06-16-2011, 03:15 PM   #9
QuoteOriginally posted by Caddis Quote
Im using Pentax 16-45mm. No sensor cleaning.
Yeah. Looks like it. Tried frcing it down on my k10d. Succeeded but when taking pics again. The shutter will again be jammed.
QuoteOriginally posted by JeffJS Quote
I dunno. I thinking the culprit maybe the memory card. :ugh:
QuoteOriginally posted by TomK Quote
And as K57XR said -
I dont think so. Im using the Pentax 16-45mm Only. And pentax Fa 50mm f.14.
Later i will post some examples of the pictures. Thanks for the responds guys
06-16-2011, 03:23 PM   #10
The pictures:
1. First it was half black half coloured:
2. After that, all black. the hell.
06-16-2011, 06:22 PM   #11
rfortson's Avatar
Have you tried a different card?
06-16-2011, 06:24 PM   #12
rfortson's Avatar
Yes, check the card. That should be the first thing (easiest thing) to check in situations like this.
06-16-2011, 06:35 PM   #13
QuoteOriginally posted by rfortson Quote
i tried on my two cards though. other cards not yet. i try using other cards then.
06-16-2011, 07:41 PM   #14
I don't see how it could be the card. It seems to be saving the file recorded by the sensor. Looks like the sensor is being blocked. Could be the shutter is not opening or the mirror is not flipping up when an image is captured.
06-16-2011, 07:56 PM   #15
QuoteOriginally posted by dvest Quote
the shutter curtain in not move down. when i set to "Sensor Cleaning". the sensor is covered by the shutter curtain.
it puzzles me which may cause this problem. impossible shutter died on both camera suddenly. must be either the lens or memory card causing it.
camera, dslr, half, images, k-7, k10d, photography
Black specs on images Pritch Pentax DSLR Discussion 4 08-23-2010 09:04 AM
K100D - Images are black Aussiepentax Pentax DSLR Discussion 9 12-28-2009 09:13 PM
New K10D sometimes shots black images. rcl Pentax DSLR Discussion 7 03-23-2008 01:07 PM
New K10D, starting to record "Black" images intermittently mhuterer1 Pentax DSLR Discussion 13 12-28-2007 12:16 PM
All times are GMT -7. The time now is 01:23 AM. | See also: NikonForums.com, part of our network of photo forums!
