11-17-2007, 02:31 PM   #16
I use custom setting, with B+6 (one step from the far blue side of the quadrant). Seems to be perfect for indoors with usual lamps w/o flash. Anyway, setting custom WB in K10D is SO easy, that it's not a problem at all.
11-17-2007, 03:55 PM   #17
bluespearbone's Avatar
Anyone tried the Expodisc?
I use a cheapo white plastic lens cap thing to set it (sometimes).
11-18-2007, 07:17 PM   #18
white balance
I'm a newbe to this white balance, the manual says to use white paper to set the wb. Is there a easy and cheep way or must I buy what I've seen on line? or is there another way like use the white body cap that came with the camera?
thank You:
11-19-2007, 06:48 AM   #19
Lowell Goudge's Avatar
QuoteOriginally posted by Gale Shaffer Quote
thank You:
Forget all of that. Assuming you have a K10D, just take a photo and then select Fn use the selector to pick WB and then you will see an interactive display of your last shot that changes as you adjust the WB.
Using a sheet of paper is not the same as getting your images (skin tones, whites, etc where you want them.
11-19-2007, 08:51 AM   #20
mattdm's Avatar
thank You:
If there's something color-neutral (white, or neutral gray) around that's being lit by the same light-source as your subject, simply use that as your target when you're setting custom WB. Then tweak slightly on the grid 'til it looks right.
11-20-2007, 12:02 PM   #21
Mechan1k's Avatar
I take a test shot first ... and then adjust WB accordingly ... if i don't like the presets available. I then manual choose what I want (but that's rare though).
auto, auto white balance, balance, camera, dslr, flash, indoors, photography
K-7 Auto White Balance problem bymy141 Pentax DSLR Discussion 16 09-26-2009 11:07 AM
K10D white balance Tommy Pentax DSLR Discussion 8 09-18-2009 01:39 PM
K-7 Auto White Balance lawsonstone Pentax DSLR Discussion 4 07-11-2009 04:57 PM
white balance simons-photography Pentax DSLR Discussion 4 04-13-2008 01:59 PM
Auto white balance vs. daylight balance outdoors. fevbusch Pentax DSLR Discussion 7 02-18-2007 03:04 PM
All times are GMT -7. The time now is 10:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
