11-15-2007, 05:24 PM   #1
Canada_Rockies's Avatar
K10D + 12-24 + 50-135 Here!
Today FedEx knocked on my door, and I am now setting up my K10D, D-BG2 grip, DA 12-24 and DA* 50-135. I've done the firmware update, and taken a couple of indoor snaps with the 12-24 using Shake Reduction. Christmas and Easter and Birthday all in one!
11-15-2007, 06:57 PM   #2
vievetrick's Avatar
CONGRATS!!! Lets see some pictures!
11-15-2007, 06:57 PM   #3
those are some very sweet lens setup there.
11-15-2007, 07:37 PM   #4
I was just like you are now about 3 weeks ago. Fun.....isn't it?
11-15-2007, 08:10 PM   #5
jgredline's Avatar
Very cool and be careful of LAD....
11-15-2007, 09:03 PM   #6
QuoteOriginally posted by jgredline Quote
I must admit that the DA* 16-50/2.8 is ordered, on backorder. I have had a severe case of LAD for many years (see my sig for proof)
11-15-2007, 09:06 PM   #7
QuoteOriginally posted by vievetrick Quote
I just took a couple to see if my sensor was square, and it seems to be. I then took another using the 12-24 to see if the warning about flash incompatibility was true. It is. Emphatically.
11-15-2007, 09:45 PM   #8
jgredline's Avatar
QuoteOriginally posted by Canada_Rockies Quote
I just took a couple to see if my sensor was square, and it seems to be. I then took another using the 12-24 to see if the warning about flash i was true. It is. Emphatically.
Can you please elaborate a little on this? I did not know there was a lens/flash incompatibility.. How do u know?
11-15-2007, 09:45 PM   #9
jgredline's Avatar
Yep, I know what u mean.
11-15-2007, 10:21 PM   #10
rvannatta's Avatar
well the problem with the 16-50 f/2.8 and the built in flash is that the front of the lens creates
a shadow in the center bottom of the photo
11-15-2007, 10:27 PM   #11
jgredline's Avatar
QuoteOriginally posted by rvannatta Quote
So with an external flash this should not be a problem?
11-15-2007, 11:01 PM   #12
In the K10D manual, page 177, compatibility with the built in flash, the DA 12-24 mm F4ED AL is simply marked NO for use of the flash. This image shows not my "fat head", but the lens as a large shadow at the bottom of the photo.
11-16-2007, 05:59 AM   #13
Should be noted that this is a problem with all makes and brands.
11-16-2007, 06:03 AM   #14
Why would you spend upwards of $500 (or more) on great optics, and then use the underpowered non-bounceable built-in flash? If you care about image quality (which someone who buys the DA* lenses surely would), you should really invest in a nice hot-shoe flash.
(yep, I'm a flash snob )
11-16-2007, 06:06 AM   #15
Have you tried using a reflective surface(tin foil or matt silver card) to create a inverted snoot....not very high tech or flattering out and about but still might work.
camera, dslr, k10d, photography
K10D and Pentacon 135 Electric ducdao Pentax SLR Lens Discussion 16 05-07-2010 04:40 PM
K10d/DA*50-135 Bramela Pentax SLR Lens Discussion 10 11-07-2008 12:56 PM
DA* 50-135 won't focus on K10D beyond 90mm fsdogwood Pentax SLR Lens Discussion 8 10-20-2008 10:16 AM
Which bag for a K10D + 50-135 cooldude14es Pentax Camera and Field Accessories 3 06-01-2008 05:43 AM
K10D and 135 2.8 A problem..... mattv Pentax DSLR Discussion 2 09-13-2007 10:01 PM
All times are GMT -7. The time now is 11:07 PM. | See also: NikonForums.com, part of our network of photo forums!
